67 Impala Lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2009, 06:05 AM
67 Impala Lights
Good Morning Guy's,
I am troubleshooting a 67 Impala with a electrical problem. The tail lights do not come on. Can some one attach a wiring diagram that covers the circuits that run the tail lights, brake, turn signal, headlights? I would be very greatfull......
Old 01-08-2009, 06:57 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Don't have one for a '67 but this site goes to a '65 that may help you for the tailights http://www.tocmp.com/tOCMP/wiring/57...roletindex.htm It should basically be the same for the tails. You need to check your grounds first, and then your hots to see if you are getting any juice to the lights. If not juice to them, then you are going to want to check your light switch and see if you are getting juice to it. If you have hot to that, you should have hot coming out. The easiest method will be to pull the switch and then get the plug down and plug it back in to where you can work on it. Other than that you will be upside down under the dash. If you have juice into the switch and coming out of the switch, you have either a bad ground, broken wire, or blowed bulbs. Also make sure there is no rust or corrosion in the sockets.
Old 01-08-2009, 07:05 AM
67 impala
Thanks alot.......Now I can start with some confidence.....
Old 01-08-2009, 12:24 PM
67 Impala Lights
When I hit the dimmer switch to low beam, the running lights go off, when I switch to high beam the head lights go off, and the running light comes on. Do you think the dimmer switch is bad, or the headlight switch?
Old 01-08-2009, 12:26 PM
67 Impala Lights
I meant to say with dimmer switch in high beam, the headlights go totally out, and the running lights come on.
Which Butyl tape to use for 67 Impala windshield impalaalex Body - Exterior 3 08-10-2007 07:24 AM
67 c6 impala 67c6impala Introduce Yourself 1 05-16-2007 04:49 PM
67 Impala....performance questions Jonpenn Hotrodders' Lounge 4 01-02-2003 05:21 AM
67 impala steering box bukweet Suspension - Brakes - Steering 0 12-18-2002 05:52 PM
Windshielf for 67 Impala doctormidnight Body - Exterior 3 12-13-2002 06:50 PM
