67 Mustang Cable Clutch Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2007, 02:12 PM
I am attempting to upgrade to a cable clutch in my 67 Mustang coupe, still hanging onto the toploader but upgraded the scatter shield and clutch to cable type diaphragm duel friction.
The hard part has been the clutch cable, wont say the source but the system I got was one that called for a modified welded pedal bracket and drilling the fire wall. So far the modified pedal wont fit under the dash, despite the "minor dent" I had to pound in the lower cowl.
Anyone running a cable clutch in a 67 that has had good luck experience with other types, preferably the non welded/drilling types - or Hyd clutches?
Thanks, Gydyup
Old 02-08-2008, 02:09 PM
I just installed a clutch cable kit from Modern driveline, although in a 65. He also makes a kit for a 67. Mine is close to the underside of the cowl, but it bolts to the clutch pedal, and is adjustable vertically. I had my instrument panel out while installing it, so I could see how much clearance I had, and just slid it down until it cleared. I haven't used it yet, still going together. What brand did you install?
John
Old 02-10-2008, 12:30 PM
i did a cable clutch and had clearance issues with my header AFTER i had already drilled my firewall on my perfect original steel 68 fastback. I'm removing it and going with a hyd clutch.
Old 02-10-2008, 02:21 PM
Drive it Like u Stole it!
ANY cable system will have interference issues with the driver-side header, if you're using headers vs manifolds. the cable has to loop back around to the bellhousing and in most instances with headers, the "extreme" 180deg that is there will both burn against the header and cause unsteady pedal feel because of the bind. ultimately, the better choice is to go hydraulic, if you dont mind running new custom bent hydraulic lines. otherwise, the stock z-bar setup works fine.
cable clutch on gm t5 pats 5speed ss Transmission - Rearend 8 01-05-2007 04:55 PM
Double Trouble 67 Mustang To Muscle exiled1 Hotrodding Basics 5 10-28-2005 08:38 AM
the simulated vents on a 67 mustang 67stangnut Body - Exterior 2 12-29-2004 09:45 PM
