67 Mustang Fastback shock tower hat - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2005, 05:28 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I hope someone can help me, I've been searching the net for days trying to find the correct hats. Please refer to the crude diagram below.
The center to center measurement on the top of the shock tower is 3 /3/4 (b to c) for the body side bolts and 4 1/4 from either outside bolt to the engine side bolt (b to a) or (c to a).
I have 2 sets of hats, but both measure 3 (b to c) and 4 (b to a) or (c to a).
I have found a 69 GT500 with the same pattern, but can't seem to find them anywhere on the net. Distributor,part name or part number would be most appreciated.
(engine)
(a)
(b) (c)
Thanks,
Bob
Old 11-10-2005, 06:51 PM
aka Duke of URL
By hats I assume you mean the upper shock mount that sits on top of the aprons?
C7ZZ 18A017-A Front Shock Absorber Upper Mounting Bracket
Can you show photo?
Old 11-11-2005, 12:31 AM
AngliaBob's Avatar
Kultulz,
Yes, I am talking about the upper shock mount, which bolts to the shock tower.
I will try to get a pic and post 11/11 in the PM.
I couldn't find a pic or description of C7ZZ 18A017-A Front Shock Absorber Upper Mounting Bracket
Thanks,
Bob
69/70 Mustang Shock Tower Removal Bayouboy2022 Suspension - Brakes - Steering 4 06-01-2005 02:38 AM
Mustang II stock shock tower length? sodas38 Suspension - Brakes - Steering 1 10-25-2004 11:40 AM
Suspension Mods for a 67' mustang, help!? Pencilneck314 Suspension - Brakes - Steering 13 06-25-2004 06:31 AM
67' Mustang fastback cowl grille replacement Pencilneck314 Body - Exterior 0 01-16-2004 09:10 PM
67 Mustang Fastback wanted Mertz Hotrodders' Lounge 4 10-16-2003 07:56 PM
