67 mustang...feels the like the brakes are applying the whole time! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2006, 01:07 AM
I just finished rebuilding a 67 mustang ! I Had no choice in taking the 289 out completely and putting in a 302! Also i put 4 way disc brakes! when driving, it feels the brakes are applying continuously and the brake pedal i stiff as a stone!!!! When you hit the gas and then take your foot off, you thrust forward like as if you were hitting the brakes hard!!! Now my first thought was that the master brake cylinder pin that goes into the booster is too long BUT any help you guys can give me would be very appreciated!!
Old 05-26-2006, 03:12 AM
Did the disc brakes come from a donor vehicle or did you buy a kit? If you are using an emergency brake, could the cable be hanging up on anything, does it release completely? I'm assuming they bled normally, could there be any kinks in the lines?
I've seen something similar when the pushrod was adjusted too long and there was a preload on the MC, but shouldn't happen unless you made some changes. Did you change anything else like the MC, proportioning valve, booster, pedal or pushrod?
You may want to try loosening the 2 nuts and see if the MC pushes away from the booster with any force. If there is no preload, you should be able to hold it flush against the booster with very light hand pressure.
67 Mustang Frame repair ???`s Grey80Ghost Suspension - Brakes - Steering 15 08-03-2003 06:22 AM
350 into 67 Mustang Nate_Owen Engine 31 07-11-2003 12:36 PM
Ram Air Intake - 67 Mustang hot rod jerry Engine 4 06-26-2003 04:38 PM
67 camaro brakes? mooseman Suspension - Brakes - Steering 0 04-30-2003 11:51 PM
'67 Mustang Trans 2nd & 3rd gears going. 67 302 Transmission - Rearend 0 02-09-2003 05:13 PM
