67 mustang K/H 4 piston discs...nice! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 09:50 PM
001mustang's Avatar
Can not believe how cheap the parts are.
How do they make a profit?
K/H 4 piston caliper w/ pads and clips=$79.
Rotor = $34
Two brackets=$105.
Hose=$10
Drum/drum master cylinder=$17
Misc hardware=??.
Would prefer the larger T-Bird setup but to cheap to buy the $400 brackets.
T-bird only disadvantage is more unsprung weight and $.
Wow! The difference is Wow!
Can stop quickly w/ no hands.
Pedal effort on par w/ drum/drum.
So easy to install and change pads, unbelievable.
I feel the braking is far safer than drum/drum.
Had metal ball "junk shot" in one caliper port; wouldn't bleed.
Removed the 4 pistons and cleaned the metal balls out; very easy.
I ceramic coated master cylinder, rear drums, etc.
ID:	49017   Click image for larger version
ID:	49019   Click image for larger version
ID:	49020   Click image for larger version
ID:	49021   Click image for larger version
Old 10-17-2010, 10:02 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Nice job, Good luck with it.
Rich
Old 10-17-2010, 10:23 PM
001mustang's Avatar
Thanks!
I'll try to keep her between the ditches.
Compress Mustang rear disc brake caliper piston 75gmck25 Garage - Tools 12 01-24-2016 05:42 PM
67 Mustang Quarter Panel Replacement Morgan22 Body - Exterior 8 07-16-2010 02:30 PM
A nice gold recommendation for my '67 Stang HHStang Body - Exterior 3 05-22-2007 06:21 AM
Double Trouble 67 Mustang To Muscle exiled1 Hotrodding Basics 5 10-28-2005 08:38 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
