I bought a 67 Mustang coupe to build a daily driver. Mechanically it's pretty good, recent rebuild on the original 289. I'm nowhere near to actually replacing the quarters but maybe I'd better run this past you guys in case I've got it all wrong and need to rethink what I'm doing.
Here's the quarter panel on the drivers side I need to replace on my 67 Mustang coupe. Passenger side is about the same condition. This is exactly how I bought the car with the exception of the Ford Ranger wheels I put on it to replace the really small wheels that were on it, I guess in an attempt to lower the car. Thanks to our dry weather out here, no rust so far from the exposed bare metal.
If you look close you can see the rust holes in front of and back of the wheel well. I intend to strip it to bare metal a panel at a time and epoxy prime with SPI and then do the body work on top of that once I have the whole car primed so I can see it all one color.
I expect I'll have to repair the outer wheel well something like this.
The drivers side quarter panel I got from a rust free coupe here in New Mexico. I have both sides.
Looks like original paint and no repairs, I really lucked out on these.
Here's how they are cut at the sail panel. I'm thinking I want to cut the car to match with the exception of continuing the cut right above the wheel well straight forward to the door jamb as in the picture below.
I don't think I want to attempt to attach at the point of the forward junction of sail panel and quarter panel in the corner. The car shown below has the car side flanged and attached with screws as you can see. I want to butt weld mine.
The rest of the quarter will be attached at the spot welds at wheel well, door jamb, tail light panel, rocker panel and trunk drop off and into the trunk seams shown below.
Well thats the plan and I'm hoping it's a good one. What do you think? Am I overlooking anything? Will matching the cut at the sail panel be a nightmare to line up with no gap? I am in no hurry at all and will cut the car "long" and bring it down to match the cut in the quarter a little at a time till it matches.
I have a good mig w/argon mix and from reading here I will be using .23 gauge wire. I would say my welding skills are fair to good. I have a good 2 stage compressor 80 gal. tank. Air tools, chisel panel cutter, body saw, die grinder, cut off tool, etc.
From reading this board I've seen many different ways to do this like cutting an inch below the top body line and welding along the entire length of the panel. This sort of scares me as I don't want to warp the panel with my welding and I do have some damage on the car at the top of the panel next to the trunk but I think it could be repaired.
If it were yours how would you do it? Really could use some input here guys.
Morgan
