67 mustang universal rod door panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2004, 07:28 PM
Last journal entry: Cowl Panel RUST!
just a thought. I wanted to use the flame universal door panels on my 67 stang and was wondering if it would be possible to cover a whole mustang door with the universal door panel instead of the small area that the mustang door panels cover. i think i remember seeing a mustang that had this done to it once before. I want the panel to cover the door from the bottom up to where it meets the window.
Old 10-05-2004, 08:28 PM
Restore60s's Avatar
Door Panels
I use Rod Doors alot. I'm not sure if they will work on the Mustang. However you can take Vinyl Top padding and draw your flames out then cut the pattern and glue it to your panel. Then lay your material over the flames and glue it down. Use 3M 8090 Trim glue to do this.
