67 Nova engine swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 09:37 AM
Ok guys here's whole story.my daughter has a 67 Nova ss that she's had for 25yrs California car,our father daughter project car.She moves to Oregon for a few years and comes back without any emissions on the engine.Well the engine blew a rod destroyed the block 15 yrs ago.Now it's time to get it ready for the Grand daughter. The question is what to do about a engine for this this.I did pick up a couple of engines over the yrs only to now find out...thanks to site [which is a blessing by the way] that they are Truck engines and after reading posts on this site I find out I can't use them since were are in California....and she never registered the car back to California from Oregon. I need suggestions on which is the best way go? Old or New?
I appreciate your Knowledge in advance
Old 06-20-2010, 01:18 PM
JeffB's Avatar
That should not even be an issue,if you were to buy a block from any rebuilder source there is no guarantee what core you would receive for a SBC.However there is a slight difference between the 63-67 Nova blocks and other SBC's as far as the oil filter mount where you would require a shorter filter,checkout Mortec.com for the Nova casting numbers to look for, you may also put up a post in the classifieds here for a Nova core.
Old 06-20-2010, 01:31 PM
ericnova72's Avatar
More for Less Racer
Isn't '67 old enough to be exempt from emissions testing and the like in Cali now. I thought it was a 30 years rolling date of exemption, or is it totslly Nazi there??
Old 06-20-2010, 08:57 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
Its still totally Nazi here. The law states you are only exempt from testing not that you can remove your emission devices. I believe that year only requires a PVC and a thermal air cleaner. That's what the law says but the officer has to know that and most don't bother. I would just put any engine in there you want. If you do a standard small block no one will ever check the casting number to see what it was. When you register it in California it will still be registered as a 67. Don't worry about it and just have fun.
Old 06-20-2010, 11:28 PM
620 dude,
you didn't say which motor was in the car, 6 or 8cyl, I don't think you could get the 4cyl in an SS Nova.
Old or new, you will need new heads with hardened valve seats for unleaded gas.
Have fun with it.
Old 06-21-2010, 03:01 AM
It's actually a good thing you waited this long. Back in '88-'89 when I converted my '67 to V8, replacement parts were hard to come by. I only found ONE place that had frame-mounts for a SBC. J&W Nova parts. This was before internet, so all we had were magazines. Because of that I couldn't find a replacement front-sump pan/pick-up either. It was a blessing in disguise I guess. I ended up learning how to improvise, and figured out what will, and won't work, in these swaps.
If yours is an original V8, and the rod only damaged the block, at least you still have the external bolt-on parts to re-use. If you're converting inline-6 to V8...you're lucky. It's soooo easy to get reproduction parts now.
Old 06-21-2010, 09:17 AM
The car came with a factory 327 but when it blew we lost the block and the oil pan...pretty ugly. I was thinking when it left for Oregon it had an smog pump on it? where would I look to find out what emissions came with the car?
It's been so many years ...I can't remember.
I appreciate your guys knowledge and input it helps alot
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
'66 mustang engine swap RacinJason68 Hotrodding Basics 8 04-19-2010 08:43 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
67 camaro swap 72 nova std. steering box digger67 Suspension - Brakes - Steering 1 10-14-2006 08:58 PM
