Good day everyone. Came across this 67 and wanted to know if it's even worth $6500? It appears to be losing oil pressure about 5-10 minutes after starting so might be a spun bearing or worn bearing or camshaft bearing so looks like bottom end job I required. The oil pressure drops to about 10 psi at idle and goes up to about 20-25 while driving. Here is the info on the car:
Engine is from a 71 toronado 455 and it was rebuilt last December with new heads then taken a part to put in a 501 lift 289 comp cam, no water leaks, no smoke no oil leaks, interior is nice no one has even sat in the back seats new seats belts capet headliner and all, it has a Richmond 390 positraction, little to no rust now body has been sanded little bondo hear there on hood had little rust on it but cut a hole under hood scoop which you cant see where the rust was and now looks good and works with the clainducted intake and underneath has been undercoated, has power steering and new fluid, was repainted last October has one or two small bubbles.
Includes-
- new interior, seats, headliner, door panels
- new front disc brakes, rear air adjustable shocks and new front springs and shocks- new carburetor and aluminum intake
- new chrome wheels
- new heads and gaskets
- new cam 501 duration 289 lift
- new lifters
- new bell housing
- new clutch
- new pedals
- new radio needs to be hooked up loose wire I think
- new custom fit speakers
- new 390 Richmond ring and pinion and positraction
- munci four speed four on the floor
- new paint, interior, racing bucket front seats
- new clainducted air intake
- new gas tank
- new fan
- new aluminum radiator
https://flic.kr/s/aHsk2BvXaC
Includes-
- new chrome wheels
- new lifters
- new bell housing
- new clutch
- new pedals
- new gas tank
- new fan
