67 Pontiac 428 carb replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2010, 11:19 AM
60smotorhead's Avatar
I've got an all stock 67 Grand Prix 428HO that needs a carburetor (Quadrajet slowly leaking gas through bowl/?, missing primary rod springs/valve retainer ring, etc). I know there are people who can rebuild/supertune this (though I've read 67 Quads have a design problem with float pressure on needle because the pivot/lever ratio is too short), but for now I'd just like to get a replacement carb.
Is a Holley or Edelbrock better? I have a Holley double pumper spreadbore (not sure model/CFM) on another 428 GP and it runs like a champ, but I want to learn more about this.
I figure I should get a 750 cfm with vac secondaries, and would like to keep a spreadbore (better mileage with small primary venturi?, and to avoid an adaptor/manifold change) but all input is appreciated.
Old 07-17-2010, 11:47 AM
DoubleVision's Avatar
I would go back to a Quadrajet, it`s the best street carb there is.
Call up Jet Performance or Sean Murphy Induction. They both specialize in completely rebuilt Q-jets and they will build it to your engine spec`s. The replacement Q-jet from either one will be of the much newer variety with a electric choke. Both have web sites. Just go to your search engine and type in the names.
Old 07-18-2010, 03:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the carb is original, don't let it get away from you!
A couple more places:
Gessler has most if not all of those parts you need.
Ruggles has quality parts and rebuild kits and services like primary bushing installation. He does correct restoration of Q-jets, too.
Good luck.
Old 07-18-2010, 10:45 PM
Bigolotava's Avatar
Double Vision:
A well-rebuilt, properly tuned Quadrajet will give you crisp performance, great mileage and keep that GP original.
Follow Cobalt 327's advice and seek-out Cliff Ruggles to overhaul your Quadrajet... while the float fulcrum was indeed moved forward in later years, your carburetor is fine as-is!
At the very least, read Cliff's Q-Jet book which will walk you through various tuning recipe's as well as showing how to do an in-depth rebuild. Its available via his website or on e-Bay, Amazon or any place that sells automotive books.
If you prefer, Cliff will repair/overhaul/tune it for you. You can advise him what mod's (if any) you've made to the engine/drivetrain and he'll make the necessary mod's to the fuel curve on the idle, transition, cruise and secondary circuits, not to mention properly adjusting the Air Valve, Choke Pulloff and more! http://cliffshighperformance.com/
Old 07-19-2010, 04:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another comment or two about Ruggles: He runs a Pontiac himself. He likes the Pontiac version Q-jets to modify for use on other makes, so he's real well versed in Pontiac/Q-jet combinations.
He ain't cheap, but he gets good reviews from those who've used him and he seems to have real good "after the sale" service.
Old 07-19-2010, 04:24 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Cliff spends a little time here: http://forums.performanceyears.com/forums/ He answers a quite a few questions and gives advice, sometime.
Carb interchange years ? 67 Mustang 6 cyl F&J General Rodding Tech 5 12-14-2008 08:01 PM
67 GTA fairlane w/ 428 CJ hot428ford Introduce Yourself 2 02-07-2006 10:34 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 02:10 PM
Proform replacement for Holley carb body, worth it? Pinardi Engine 2 01-07-2003 06:51 PM
What's a good tranny replacement for my 62 Pontiac Catalina? Albert Wallace Transmission - Rearend 5 04-10-2002 08:16 AM
