67 rambler rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2003, 12:57 PM
amc's Avatar
amc amc is offline
Angry 67 rambler rear end
not like any of you will probably know this, what is the length from where you bolt the rear end up on one side, to the same place on the other, on a 67 rambler american. Or, where could i find that information to verify what i measured (50.5 inches).
I'm trying to find a ford 8.8" rear end to put on (cause i probably can't afford a 9").
Old 06-17-2003, 05:39 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
I have a '69 Rambler. I'll take a good look at it next time I work on it, probably in 2-3 weeks. You're talking about spring to spring, right? I'll take the measurements and send you a pm after that. I was looking at a ford 8.8 or a GM 10-bolt from an early nova. However, a I'm pretty sure that a rear axle from an AMX will fit right in, and it can handle a fair amount of power.
Old 06-17-2003, 06:36 PM
bad429's Avatar
I saw a 8.8 from a late model explorer under a amc last summer? Dont know how much modifying there was. Good luck
