Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 12-22-2002, 02:33 PM
blown57's Avatar
blown57 blown57 is offline
Post 671 blower glowing headers
I am running a 350 small block & a weiand 671 blower, 2 500cfm carters. Edelbrock aluminum heads,comp blower cam. The engine had been running great but I noticed this evening that it was popping out the passenger side exhaust when I started the engine. The headers are also glowing red to the collectors which I have not noticed before.
Any advice would be greatly appreciated,thanks for your help.
Old 12-22-2002, 04:16 PM
HemmiGremmie's Avatar
HemmiGremmie HemmiGremmie is offline
stud man!
Post re: 671 blower glowing headers
Mess with your timming. Check out the Blower Drive Website, but I believe that usually means your timming is to advanced. Lets see some pics. Love them blowers. HG
I was built with the body of a God! To bad it was buddah.
http://www.hotrodders.com/forum/jou...&journalid=2415
Old 12-22-2002, 07:16 PM
6-71 sbc's Avatar
6-71 sbc 6-71 sbc is offline
i think that your carb might be too small. i am running a pair of 750 double pumpers on my small block. did you notice what you engine temp was? and yes check your timing set your inital timing at 18 degrees and total at 32 at 3000 rpm for street driving witch i think you do with a pair of 500. gas what kind 92 pump or 101 race.
Old 12-22-2002, 07:18 PM
6-71 sbc's Avatar
i for got to say is the popping is from your cylinder is so hot that it is igniting any gas before the exuast is closing
Old 12-23-2002, 01:12 PM
blown57's Avatar
I will check my timing, I think it may a little off. Thanks for the help, I really appreciate it.
Old 12-23-2002, 01:15 PM
blown57's Avatar
Oh yea, I am running 92 octane pump gas. Could be the gas, I just added about 10 gallons.
Old 12-23-2002, 01:37 PM
roys63's Avatar
roys63 roys63 is offline
Are you running the blower overdriven? If so the pump gas will not get it! Did you set your popoff valve springs?
Old 12-23-2002, 07:32 PM
blown57's Avatar
The blower is underdriven, about 7psi boost when hammered. I have driven this car quite a bit and only recently experienced these problems. Is the cause of red headers advanced or retarted timing? I checked the BDS web site and they stated it is caused by improper timimg but didn't say which way.
You can take a look at this pro street 57 chevy by going to:
hometown.aol.com/rjthomas57
Thanks for all the replies, I do appreciate the input.
Old 12-24-2002, 08:47 AM
steppenwolf steppenwolf is offline
verynice ride, rj... i second the gas question... same filling station as before? does the popping quiet down once the engine's warmed up?
-z-
Old 12-24-2002, 09:35 AM
TheDude7667 TheDude7667 is offline
Why the hell do you have headers on in the first place? If i were you, i'd take those stupid things off and put on your stock manifolds. Those headers are too thin, and headers are worthless in blown engines.
Old 12-24-2002, 11:01 AM
blown57's Avatar
Yea they are thin and a real pain in the *** . I my go back with a set of S.S. sanderson manifolds and get away from the headers and all the B.S. that goes with running them.
Thanks for the reply
Old 12-25-2002, 06:47 AM
roys63's Avatar
[quote]Originally posted by TheDude7667:
<strong>Why the hell do you have headers on in the first place? If i were you, i'd take those stupid things off and put on your stock manifolds. Those headers are too thin, and headers are worthless in blown engines.</strong><hr></blockquote>
You can not be Serious!!!!!!! STOCK MANIFOLDS on a blower motor!! NOWAY! NO FLOW it Will run like **** and HOT!!. DON'T LISTEN TO THIS CRAP!!!
Old 12-25-2002, 07:16 AM
Infomaniac's Avatar
Infomaniac Infomaniac is offline
Check Out My Photo Album
Don't choke that engine taking the headers off !!!
A lot of times the engine is rich causing the headers to glow. Fuel burning in them. Check your power valves and float levels.
Old 12-25-2002, 08:20 AM
ptu's Avatar
ptu ptu is offline
Usually red hot headers are due to late ignition timing. Running vacuum advance? Be sure to set timing with vacuum advance disconnected. You should be running around 10 degrees advanced or
more. Be sure to use the correct rated octane rated fuel for the compression your are running. If the headers glow red in a very short time after start up, correct the timing. Thanks, Barry.
Old 12-26-2002, 07:45 AM
blown57's Avatar
Yes the headers did glow very soon after starting. I will advance the timing a bit and see what happens. All the replies have been great ( except the one suggesting going back with stock manifolds). Thanks again
Back to top
This discussion has been added to the Engine Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
