Hotrodders Bulletin Board
#1
671 Blower Pulleys...Help pls!!!!!!!!!!!
ive got a 36 & 32 tooth pulleys for my 427 Chevy. Does the 36 on top make it under driven????? I,m running a fine line at 9.8 compression, or can i keep the 32 on top?????? thanks Marty
#2
re: 671 Blower Pulleys...Help pls!!!!!!!!!!!
That must be a 1/2" pitch pully, placing the 32 tooth on the blower will give you +12.5%, the 36 on top should be -11.
12.5% overdriven with 9.8 static c.r. will put your effective c.r. through the roof, without calculating it, i'd estimate 14 or 15:1 easily.
You can't run with the big dogs if you pee pee like a puppy... |
#3
671 Blower Pulleys......Help pls!!!!!!!!!!!!!!
Thanks......well that sucks bigtime!!!!!!!!!!!!! My friend Neil races a blown 30 Ford on the Nostalgia circuit. He said big pulley on top for under driven. Now the 36 pulleys centre hole is to big & the 32 pulley centre hole is to small to fit over the belt pulley...........guess theres more machine work to do!!!!!!!!!!! Marty
#4
You could always try an MSD BTM to pull timing out but that's a lot of cylinder pressure for a non-O-ringed block when in boost. I see guys claiming big OD on their street blower motors, and huge boost numbers for turbos on the street, curious how they work out.
#5
Your right about the boost & compression...got no choice i guess! the 36 on top & 32 on the bottom. I never really drive the truck hard anyways....can,t afford broken parts!! Will keep you updated......Thanks
Back to top |
Similar Threads for: "671 Blower Pulleys...Help pls!!!!!!!!!!!"
| my 671 snout is too long? Blower pulley doesnt line up with crank pulley | darkostoj | Engine | 10 | 01-11-2008 09:30 AM |
| will this 671 blower work on my sbc? Offset snout? came off a 351C *pics* | darkostoj | Engine | 5 | 12-09-2007 11:25 AM |
| 671 blower, changing top end | deno | Engine | 8 | 02-09-2006 03:45 PM |
| 671 blower glowing headers | blown57 | Engine | 38 | 01-28-2006 10:04 PM |
| My 671 Blower...HELP PLS!!!!!!!!!!!!!!! | binder47 | Engine | 3 | 09-09-2005 04:37 AM |
