Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 671 weiand blower on 351w (problems)
Old 10-03-2010, 06:23 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Senior Curmudgeon
Wiki Edits: 326
Max pressure for a Holley is 6 1/2 psi at the bowl inlet. Regulate your pressure to 6 psi. No need to run the pressure right up against the wall. More pressure will blow fuel past the needle and seat and into the manifold and create tuning nightmares like you are describing.
