67firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2006, 01:52 PM
67firebird
hello everbody. Iam looking for a 60 pound pressure oil pump with a 3/4 " pickup tube for a Pontiac 400.engine.and also a 60lb spring to fit. my 80lb pump.
Ihave a 80 lb.Seal power pump now # 22441236.
any help on where to obtain these would be appreciated.
Thanks.
john
Old 01-17-2006, 03:04 PM
Thanks.
john
I got listings for Melling (M-54D-S High pressure) and a Melling (M-54 F 30% more pressure than M-54 D).
I would have to check whs for availability. Let me know.
Old 01-17-2006, 03:27 PM
GoneNova/406's Avatar
why do you want that much press.?i have the melling chevy M99HVS,hi vol. hi press. pump and unless you have very good oil seals you'll end up with alot unburned hardended charcoal in your exh. side of your heads.i had to cut my spring back a little.anyway i would think melling makes one of these for pontiac as well as chevy.i called melling to get a new spring and they sent one to jegs for me but told me that my pump was good for 35 at idle and 85 top end.thats just to much.although one has to remember that it is a hi vol. pump and it takes a little more umpf to push that extra oil.still i cut it to much the first time and not quite as much this time.i'm shooting for 60-65.
Old 01-18-2006, 08:02 AM
john67
thanks for info Actually i do want lower oil pressure, but am hving trouble finding pump and springs, as Pontiac only come with High Press punps 80-120lbs.
john
Old 01-18-2006, 10:59 AM
john
The Melling M-54 C pump is standard pressure.
Old 01-21-2006, 06:52 PM
oil pump
67 Firebird I've have used the Melling M-54 S pump in my GTO for years. Warm idle pressure is around 35 lbs. and highway 52-60. Have seen as much as 85 lbs at the strip at around 5500-5900rpm. Other than the typical Pontiac rope rear main leak I have had no problems whatsoever.
