68 327 motor, harmonic balancer
What size and type of harmonic balancer does a 1968 327 motor out of a chevelle take. I know that they are a large journal motor, so I was told that they take a different harmonic balancer than small journal motors.
Thanks |
should i use a 6.25 inch, a 6.75 inch, 8 inch, or some other size. Thanks
Not all small journal 327's used the small balancer. I know the 350HP 327 used the large balancer and had a crankshaft bolt in '66.
I think the high performance engines might have used the large balancer and maybe the milder versions used the small balancer. JA |
I'd go with an 8" and be done with it. You can use that on anything but a 400.
Here are all the 327 offerings with part numbers from Damper Doctor.....
CHEVY 327 C.I. 8 68 68 Only; Timing mark in line with keyway CHE3273 CHEVY 327 C.I. 8 62-64 Round holes in hub; Step in back of the ring CHE4091 CHEVY 327 C.I. 8 62-68 6.25 inch Diameter; 1.2 inch Outer Ring Height CHE3271T CHEVY 327 C.I. 8 64-66 Corvette; Nova; Finned Back CHE3272 CHEVY 327 C.I. 8 69-Up 2:00 Timing Tab Location; 6.125 Diameter CHE3071 CHEVY 327 C.I. 8 69-Up 6.25 inch Diameter CHE3271 CHEVY 327 C.I. 8 To-68 2:30 Timing Tab Location; 6.125 Diameter; Not Riveted CHE3072 CHEVY 327 C.I. 8 Up to 68 2:30 Timing Location CHE3502T http://www.damperdoctor.com/Merchant...&Store_Code=DD |
| what is the fastest (factory) car you have ever driven? | badknuckles | Hotrodders' Lounge | 320 | 12-09-2011 01:32 AM |
| 68 Impala SS 327, is it a Muscle Car(tm)? | 327ImpalaSS | Hotrodders' Lounge | 30 | 05-15-2008 08:25 PM |
| chevy 327 Harmonic Balancer Size? | 70Z28 | Engine | 5 | 12-17-2006 07:30 PM |
| 327 balancer | 70gs455 | Engine | 7 | 02-24-2004 01:40 PM |
| sbc 327 vs 350 Harmonic Balancer Question | Ted's37 | Engine | 3 | 07-14-2003 04:10 PM |
