68 390 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2007, 08:30 PM
68 390 heads
I need some help I thinking about buying a set of 68 390 Ford Heads casting #C8AE-H ----I BEEN TOLD THEY ARE gt hEADS----CAN ANYONE HERE HELP ME OUT.Need to know are they good heads --cc sizes, valve,intake and exhaust ,and anything you can tell me about them
Old 09-30-2007, 08:38 PM
Jmark's Avatar
If you have the rest of the number, you should be able to decifer them HERE......
Mark
Old 10-02-2007, 05:02 PM
The GT heads are drilled for the exhaust bolt pattern to be bolted up at an angle. I think they have 4 holes drilled in each exhaust port opening. They are no better than the run of the mill 390 head. They are set up that way so they can be used in the tighter engine bays.
Danny
Old 10-02-2007, 05:29 PM
390 cylinder heads are VERY poor flowing and performing heads.
Old 10-02-2007, 07:12 PM
onebadmerc's Avatar
I need a bucket of arc sparks
They are just a standard run of the mill 352, 360, 390 head. The only difference between them and a GT head is the exhaust bolt pattern.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
head ache. sbc heads excaliberprime Engine 7 03-07-2007 06:03 PM
68 chevy heads 79transam Engine 1 12-11-2003 01:08 AM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
What gains can i get with 401 heads on my 390 amc 73 Nova Guy Engine 5 08-13-2003 02:30 PM
