68-69 327
I have a 327 in a 1931 Chevy, going by the numbers I could locate, indicate that it is a 68-69 Corvette motor, It has dual points. How do I know what points to buy? The previous owner passed away. It rough trying to figure what I need for different parts of the car. Uuurrgg...
Thank you guy's *************** Last edited by 68NovaSS; 03-15-2011 at 10:23 AM. Reason: Violation of guidelines. Please see: general board guidelines. |
i dont know about the points but i would like to know your block no.is it 3955618?ive never ben able to find one of those blocks.
Cole |
That number means almost nothing. That casting number was used for years. There are both 2 bolt main and 4 bolt main 010 blocks. You need to read the engine ID number/VIN code ... it can tell you what the exact application of the engine in the car originally came in. ![]() General Motors did not install the 350 in a 68 Corvette. Here are the options. A 327 300 HP was standard ... L36 427 cu. in. 390hp Engine 7,717 (27.01%) $200 L68 427 cu. in. 400hp Engine 1,932 (6.76%) $306 L71 427 cu. in. 435hp Engine 2,898 (10.14%) $437 L79 327 cu. in. 350hp Engine 9,440 (33.05%) $105 L88 427 cu. in. 430hp Engine 80 (0.28%) $948 L89 Aluminum Cynlinder Heads for L71 624 (2.18%) $806 Go here for the entire option breakdown http://www.web-cars.com/corvette/opt...ptionyear=1968 The small block originally installed in a 1968 Corvette would be a 327. Either the standard 300 HP or the optional 350 HP. DEUCE ... Moderator
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Look at the driver side front of the block for the "suffix" code, it'll be the letters at the end of a line of letters and digits. The suffix can be one, two or three letters. |
I have a block that has 3970010 as the casting number as well, and from what ive seen it could either be a 68 327, which came only with a 2 bolt main, or a 69-79 350 which came with a 2 and 4 bolt main. So if its a four bolt its deffinately a 350, but if its two bolt you could be in the same boat as i am. I have been searching for two weeks now trying to find out if i have a 327 or 350. Still dont know...
As you have found, the casting code only gets you so far, now you need to research the stamped application code to define what you have. |
| Recent General Rodding Tech posts with photos |
