68-72 nova disc brake donors - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2003, 04:55 PM
Post 68-72 nova disc brake donors
Can any one tell me what donor cars are good for me to rob disc brakes out of for my 69 nova . Also how about a lemans someone told me just swap them with opposite sides and they will bolt right in thanks for any help.
Old 01-12-2003, 05:38 PM
BOBCRMAN@aol.com's Avatar
Post
nova (or clones) 68-74 or camaro 67-70 are all bolt on.
Old 01-12-2003, 07:52 PM
Post
How about the chevelles 68-72 like i was saying if you reverse sides they will fit . Thanks BOB sounds like you know your stuff throughout these bulletins
Old 01-13-2003, 01:28 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
what I got one time on www.novaresource.org/index
or try nova parts.com web site on X body disc brake swap.
1968-1974 nova
1973-1974 omega
1971-1974 ventura 11
1973-1974 buick apollo
1967-1969 camaro
1967-1969 firebird
this is the list it gave for donar cars
Old 01-13-2003, 07:10 PM
ssaza's Avatar
Post
Can use 69-74 nova or 69 camaro, STAY away from the 68 brakes,they are 4 piston brakes,unless you have a bunch of money you want to dump into the calipers.plus you would need the 2 piece rotors.As far as using Chevelle brakes,they will work,BUT Don't reverse them,[you will get a bumb steer]remove your old steering arms from your NOVA drum brakes and put them on your disc brake spindles.Just a matter of 2 bolts,Very easy change over,Can use Omega and Apollo disc brakes,What I remember about 70 camaro disc brakes is that they went to the larger spindle assy,Hope that this helps.GOOD LUCK
Old 01-13-2003, 10:37 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Post
I did this on my 71. Pulled parts off a 72. After I got the spindles rotors calipers brake lines and master cyl on, I found the rear end brakes locking up, went back and bought the rear end brake lines and multileaf springs. Then I found the driveline was shorter, bought the driveline. Lot of trouble but it worked great!!!
