68 a body question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 12:53 PM
LEE EYES's Avatar
Last journal entry: TBI experiment.
68 a body question.
i have a 68 camino as my current project. i was wondering if a set of b body spindles out of a 95 caprice would fit. anyone? thanks.
Old 03-29-2009, 02:43 PM
deadbodyman's Avatar
Wiki Edits: 11
why,because they have a 12'' rotor?the answear is yes but you have to use the upper A arm also ,I've done it.the artical was in my streetrodder magizine only one problem,if you want to keep the same lug pattern you'll have to get the rotors redrilled at a machine shop
Old 03-29-2009, 09:47 PM
LEE EYES's Avatar
because its a free disc brake conversion... lol. i wasnt aware of the bolt pattern difference though. may reconsider.
Old 03-29-2009, 10:05 PM
Wiki Edits: 11
lugs
Why,its cheap enough and you'll learn something about oldschool hot rodding.any one can buy upgrades and pay someone to put them on,but its like saving your paper route money all year and buying that spiecial bike you'll never appreaciate anything more than when you work hard to get it.hotrodding isnt about money its about knowalage and learning and hard work and the shareing of that knowalage with others. If you need any help ,just ask ,thats why were here. Its why I'm here anyways
Old 03-29-2009, 10:45 PM
LEE EYES's Avatar
cool. very true. heres the deal, i just got a t5 out of an 89 camaro for this thing. it has the factory 307 and powerglide in it, and i am not having fun with 2 gears. i have everything exept the correct flywheel, driveshaft, and i still need to fab up the trans member. i figgured the t5 would hold up to a tired old 307... i dont know of any machine shops around here qualified to re-drill rotors. i may be able to snag the wheels off of the interceptor too.
Old 03-29-2009, 11:51 PM
Wiki Edits: 11
other than starting the car the flywheel just holds the torkconverter in place it should fit and theres always adaptors for wheels but your local trade school should be able to redrill the lug holes the drive shaft may need shortining but thats not to hard either
Old 03-30-2009, 12:04 AM
prostreet6t9's Avatar
Differential/Driveline
Have a machine shop machine off the anchor stud off your spindle and you can your spindle. Buy a caliper monting bracket and the rest of the parts can be bought at your local parts store.
Old 03-30-2009, 03:54 AM
fast68's Avatar
likes chevy trucks & boobies
the old 307 didnt have much for hp top end but they had decent low rpm torque, at least as much as the mid 80s 4bbl 305 engines and maybe even as much as the L69 HO 305 engines.
but if its that tired then maybe it doesnt anymore
my first chevy engine ever was when i was 16 and it was an original 1968 2bbl hi-torque truck 307 in a '68 pickup i got for a couple grand it was all original bone stock very reliable and old man owned, was my first chevy ever
good little engines,
i killed it and put in a fresh 305 that ran freaking strong,
then i scored a fresh TRW flat top 355 for 75 bones from a 72 chevy van and i ran 305 heads milled on it and wow it was great in that truck with the original 3.73 12 bolt rear and th350 i converted to
fun times fun times
i learned chevies REALLY quick and did all my own work within a year i was doing it all and never looked back and have owned billions of vehicles since
good luck
Old 03-30-2009, 09:48 AM
First, the later B-body spindles use a different taper on the ball joint studs and tie rod end studs. You can physically bolt them up to the A-body ball joints, but the studs will not be seated properly and it WILL NOT BE SAFE.
This is the well-documented B-body spindle swap. It will not be "free". At a minimum you need the correct ball joints and tie rod ends. The lower ball joints must be machined to 2.010" diameter to fit the A-body lower control arms. You will also have a problem with getting enough adjustment in the upper control arm shims. At a minimum you need offset shafts for the upper arms, though most folks use the aftermarket upper arms from Hotchkis or Global West. Finally, if you want to keep your 5 x 4.75" bolt circle, you need to get rotors from a 1LE Camaro.
This subject comes up here about once every couple of months because someone has access to "free" B-body spindles. A search will provide more info.
Old 03-30-2009, 01:25 PM
LEE EYES's Avatar
ok. thanks. good info.
Old 03-31-2009, 06:43 AM
Wiki Edits: 11
hey Joe,When I did my conversion I used the upper control arm,ball joint and spindel as one unit (it was easier ) as for the lower ball joint why cant you just use the lower control arm too and just use all the parts from the doner car? I read this artical in mystreet rodder magizine and did it for the 12' rotors I always wonderd why they didnt tell you to use the lower control arm too,also whats the problem with redrilling the rotors? All my parts came off a 95 caprice but it looks a lot like my old chevy truck suspension. Do you forsee any problems with my set-up?
Old 03-31-2009, 07:41 AM
I was not aware that the upper control arms from a B-body fit an A-body. If they do, that's good info. I don't know if the lowers fit at all. Keep in mind that besides the ball joints, you need to have the correct suspension geometry, spring pocket location, etc. The fact that you can bolt something together doesn't mean that it's correct.
Old 03-31-2009, 08:10 AM
Wiki Edits: 11
hey joe,I just followed the directions but I hope theres no problems,I'll have to get someone to check it out since I know very little about this,Heres what I did ,subframed an 80ish camero onto my 48 plymouth,did the conversion,used the master from the donor car,an 89 camero rear with shoesand a2001 camero pwr rack,it all seams to work but I havent driven it yet I'll be taking it out the first week in may.I guess I better not go to fast on my way to the suspension shop
Old 03-31-2009, 09:25 AM
Well, the problem is you're talking about an F-body, which DOES use the same ball joints as the B-body cars. The original question was about the 64-72 A-body cars, which are completely different.
Old 03-31-2009, 05:02 PM
Wiki Edits: 11
So I should be ok then? Well Lee I guess we both learned something here,I'll get my front end checked out by the pros before I go to far or ruin a new set of tires or worse yet get someone hurt,not a bad suggestion of anyone doing suspension or brake work.Thanks Joe
newbie body question daveid Body - Exterior 3 03-29-2009 10:14 PM
1099 tax,legal question on body work amanderson Body - Exterior 19 01-30-2009 08:11 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 01:04 PM
body mount question.. APalusky General Rodding Tech 81 06-05-2007 06:58 PM
A Body mini tub question wally8 Suspension - Brakes - Steering 1 08-11-2004 06:09 AM
