I was getting a 68 skylark ready for delivery, yesterday did a saftey check of everything wipers light blinkers heater everything worked.
Today hooking up the final ac duct work under the dash and after buttoned it up started it up, fine turned on ac compressor kicked in , turned fan on , nothing, turned wipers on nothing , headlights nada??? fuses look good.
when I turned key on on, gen and oil warning lites lit up. Then I heard a groaning from voltage regulator, which is fairly new, it sounded like a flasher, I checked the emergency flasher on column and it was on.
Where do I check next? could I have knocked something loose I am in shock! no pun intended!
