68 c-10 cst v-8 engine w/ front dist.? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2011, 08:02 PM
anyone know what this engine is? it looks factory. thanks
ID:	58435   Click image for larger version
Old 09-19-2011, 08:07 PM
BOBCRMAN@aol.com's Avatar
Buick engine.
Old 09-19-2011, 10:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd hazard a guess that it's a 455, as wide as the intake looks, and having an HEI distributor. But definitely Buick.
Besides the difference in the width of the intake, on a 400/430/455, the displacement is cast into the top of the bellhousing flange at the back of the block.
Old 09-20-2011, 06:33 AM
Originally Posted by hottrodz
it looks factory.
its not factory. someone swapped it in. chevy only used chevy drivetrains in the trucks
Old 09-20-2011, 06:59 AM
lot of things can happen to a truck over 43 years.
Old 09-20-2011, 07:25 AM
Irelands child's Avatar
If not Buick, possibly could be Cadillac being so wide
Irelands child
Old 09-20-2011, 07:40 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
It's a Buick engine, Caddy engines have a valve cover more shaped like an Olds engine, narrower at the intake side and wider at the exhaust side.
One surefire way to distinguish the 2 apart is the Buick has a cast aluminum timing chain cover well over an inch deep and the Caddy is a flat stamped steel piece only 1/8 of an inch thick.
I have had a few Caddy engines, and have one on the shop floor currently, I've done a couple swaps with it and have much less knowledge of the Buick engines except for ID purposes.
In the mid to late 70's there was a small run of Oldsmobile engines coming out of the factory in GM's trucks because of a fire at one of the engine plants and to keep production going a decision was made to use Olds engines in some of the trucks. Look at all the engine options across the GM car and truck lines over the late 70's and early 80's and you will see many non brand matching combinations (Trans Am with an Olds 403, Chevy/GMC trucks with Olds diesel engines) and how about all the 231 Buick V6 engines in Chevy cars. GM didn't mind and neither did the masses for what its worth.
Old 09-20-2011, 08:30 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Another thing giving it away is Caddy doesn't have an intake mounted thermostat or ANY coolant passages connecting the heads together and the water pump doesn't have any provisions for a bypass hose like the pics the original poster shows.
Old 09-20-2011, 10:17 AM
And one more tell tale is that Caddy distributors mount vertically, whereas the Bufords mount at an angle like this one.
Old 09-20-2011, 10:43 AM
327NUT's Avatar
With all due respect Joe but the 472/500 cads have the dist. on an angle
Old 09-20-2011, 10:49 AM
You're right. Sorry for that. Don't know what I was thinking.
lowering front of engine (67 mustang) gw1626 Engine 26 12-03-2010 08:16 PM
'92 318 Dodge engine dist. turning*#@&#@ Rollinsmoke Engine 4 08-29-2010 10:45 AM
front engine dress fordoholic Engine 1 12-22-2008 09:55 AM
sbc 400 front engine noise jackfrost51 Engine 6 05-18-2006 03:37 PM
changing from points dist. to electornic dist. what to change? IHAVECHEVYPARTS Electrical 1 12-21-2002 09:20 AM
