Thread Tools Search this Thread share on Facebook
  #1
Old 09-06-2005, 05:14 PM
ronnied's Avatar
ronnied ronnied is offline
Last journal entry: 49 Ford
68 Camaro 12 bolt decode needed
I just bought 2 Camaros to restore, 67 and 68 RS cars. The 68 may be an SS also. It came with a factory installed 12 bolt(tapered at axle housing ends).
The axle tube code reads>>>PP 1003G2. I cant seem to find the PP code and most say there are only 7 digits here and I have 8?
Thanks for any help
Ron
Register now (free) or login to remove ads
Old 09-06-2005, 05:28 PM
rrmccabe's Avatar
rrmccabe rrmccabe is offline
GM Muscle
3.55 non posi 10/03 date. G2 is just gear plant, second shift.
Rich
Old 09-06-2005, 06:01 PM
Deuce Deuce is offline
Last journal entry: 32 3W
Thanks for any help
Ron
As the Moderator here......I would like to
WELCOME YOU HERE.......
As you have already seen.......lots of knowledgeable members here......
Again.......WELCOME.......
Sorry, I may have been a bit short with you...
I don't suffer fools well. I'm workin' on it
... NOT ...
Old 09-07-2005, 07:28 AM
ronnied's Avatar
thanks for decode
thanks for the decode Rich.
Im not much on drive trains but I can do a mean body. I posted some pics of the 68 RS in tear down mode. All outter sheet metal including the roof is coming off and body will then go to dipper. Im also replacing the upper dash.
Thanks again
Ron
Old 09-07-2005, 07:39 AM
rrmccabe's Avatar
GM Muscle
Glad it helped.
I am in the middle of one of those projects too. Just did not need that kind of sheet metal replacement.
Here is mine as it sits. Doing final final.... edge sanding getting it ready to paint.
Old 09-08-2005, 06:53 AM
ronnied's Avatar
Looks good. I was looking at your pics and saw the turn table you used to do the bottom. Did you make it and if so can you send more pics so I can make one.
Thanks
Ron
Old 09-08-2005, 11:03 AM
rrmccabe's Avatar
GM Muscle
Yes, I built it myself. Was a pretty easy job.
I sent Badbob some pics via email a while back. Not great but will give you the idea. If you send me your email I will forward them to you.
Rich
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "68 Camaro 12 bolt decode needed"
ThreadThread StarterForumRepliesLast Post
Distributor Tuning and Theory - Part 1Rick WIEngine3504-26-2011 12:38 AM
10 bolt to 12 boltnick62877Transmission - Rearend205-04-2005 06:26 PM
10 bolt vs. 12 bolt.IwanttolearnTransmission - Rearend402-05-2005 10:32 PM
12 bolt axle lengthsmsc66Transmission - Rearend110-13-2004 07:48 PM
How to identify Oldsmobile 12 bolt?elukasTransmission - Rearend812-13-2003 10:59 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
