I have found that a company called TRIM PARTS has the best quality for what your looking for. Most everything they make is USA made so expect to pay a little more than the average repop stuff goes for. On the sheetmetal Dynacorn is your best bet, and you still may have to trim to fit it properly.
| The Following User Says Thank You to mr4speed For This Useful Post: | ||
carolinacustoms (01-05-2013) | ||
I like goodmark for the door skins and 1/4's but I like the full 1/4's and cut them down,they fit so much better than the half 1/4's ,the floor pans are good the rear wheel outer tubs are a little crappy but the inners are good front fenders no good but only tried one and returned it never tried a second..pretty much all good with the exception of the fenders, when they offer two, get the more expensive one you'll be better off...Oh I replaced the rear frame rails too and they were perfect...the cowl hood was the best I ever got only needing a little poly putty around the outer edge and some deburring underneath ,minor hammering at the corners ,all and all a very nice hood.
On the 68 everything is about the same but the firewall and dash were very good also |
| The Following User Says Thank You to deadbodyman For This Useful Post: | ||
A close freind is a Goodmark dealer so i use some of their parts ,price is rite ,but for most consistant good fit very little prep work National parts depot has the best ive used But prices are higher ,when considering labor cost to repair cheaper parts NPD make sense to me.My opinion
Have you ever tried thier front fendersm 496 ? I have a 68 that needs a complete nose to replace a glass one...Im dreading fitting the fenders..
Not the npd ,I will be ordering 1 LF fender from npd to replace the Goodmark fende on my car 3/4" to long hood will not align grill will not bolt flush ,smaller parts or cut to fit parts are ok from goodmark but dont like their fenders. mine is a 66 ss 396 ,auto ,air . factiry air cars have different fenders, engine aws replaced in 67 a 427 400 hp.To many cars to little timd.
68 camaro
If buying sheetmetal make sure you get Auto Metal Direct. Their sheetmetal fits better than Goodmark or DynaCorn. Also check with Classic Muscle (Classic Muscle.com parts for Chevy performance and restoration ) for other parts. They are located in Winston-Salem N.C.
| The Following User Says Thank You to cdminter59 For This Useful Post: | ||
deadbodyman (01-10-2013) | ||
| 1989 Camaro with a 1969 camaro rear will it look good??? Opinions!! | nealey101585 | Hotrodders' Lounge | 63 | 06-23-2012 03:03 AM |
| new video up/ 67 Camaro painted/ red Camaro gets the boot | tech69 | Hotrodders' Lounge | 7 | 04-21-2012 11:10 AM |
| 93 Camaro converted to 96 Camaro LT1? | tylerwerrin | Engine | 2 | 09-01-2010 10:11 PM |
| 79 camaro hood hinges to 71 camaro swap | Gladis | Body - Exterior | 1 | 01-10-2008 02:17 PM |
| Will a Tilt Column from 70-81 Camaro fit 69 Camaro? | dpjmw | Suspension - Brakes - Steering | 2 | 07-04-2006 10:27 PM |
