Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 68 Camaro dash pad recovering help
Old 01-19-2013, 01:44 PM
JJ269J's Avatar
JJ269J JJ269J is offline
Thanks for the quick reply Dan. I will give that a shot. What would you suggest I use to shape the 1/2" foam? Would a flat sanding board work? I have several and a pneumatic in line sander. What grit sand paper do you use for this type of task? I will take my time with it, but do you suggest any tricks to make sure I maintain a uniform shape? Thanks again.
