68 Camaro dash pad recovering help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2013, 09:52 AM
JJ269J's Avatar
Hey guys,
I'm needing some opinions on how to attack restoring the dash pad for a 68 Camaro. The original was heavily cracked and the frame rusted. I removed the foam and cover (mostly in pieces). I wire brushed the frame to remove most of the heavy rust and plan to coat it with Rust Encapsulator before recovering. The front of the dash (leading edge) foam looks to be about 1/2" thick and it tapers down to about 1/8" at the back (see pic #2 below). So my question is, how do I recreate this smoothly? Any other recommendations for covering this? I was thinking maybe just covering the whole thing with 1/4" closed cell foam and covering that or using 1/2" sew foam but I don't know how to taper it smoothly. I was also wanting to add a seam on the top leading edge for a more custom looks with contrasting color thread. Also, because I don't know that its possible to cover the whole thing with a single piece of material. Thanks!
Old 01-19-2013, 10:45 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I would use 1/2" closed cell foam for the whole thing, and grind it down in the back. Don't put any sew foam over it, just smooth it out to your satisfaction and then glue down the vinyl over the top of the closed cell foam. Closed cell foam is very firm, and it will be easier to keep the vinyl smooth than with softer foam. You need to scuff the surface of the closed cell foam on both sides anyway, or it won't accept the high temp top and trim contact adhesive you should use to hold everything down.
Old 01-19-2013, 12:44 PM
JJ269J's Avatar
Thanks for the quick reply Dan. I will give that a shot. What would you suggest I use to shape the 1/2" foam? Would a flat sanding board work? I have several and a pneumatic in line sander. What grit sand paper do you use for this type of task? I will take my time with it, but do you suggest any tricks to make sure I maintain a uniform shape? Thanks again.
Old 01-19-2013, 12:53 PM
JJ269J's Avatar
One more question. I bought some stuff from yourautotrim.com in the past, but they do not have 1/2" closed cell foam. Who do you recommend as an online resource?
Old 01-19-2013, 01:20 PM
Wiki Edits: 22
As long as the dash is out of the car, any sander will do, but if you have a pneumatic in line sander, and a DA for the finish work, I would think that would work really well. It won't take a lot of grit to sand it down, just do a little trial and error. If you can't find any 1/2" closed cell, I have a supplier that has it. A yard of it 60" wide would be about $30 shipped directly to you. I don't know if I can buy less than a yard, but I'll check. PM me if you want me to get it for you.
My next question is do you really have to sand it at all? I'd use 1/4" for the whole thing if it doesn't matter.
Old 01-19-2013, 01:39 PM
JJ269J's Avatar
Good point. This is a custom resto mod type build, so I'm not to concerned with factory original look. I just might try the 1/4" and no sanding and see how it looks and go from there. You've been a big help. Thanks.
Old 01-19-2013, 02:24 PM
Wiki Edits: 22
You're welcome. That's why they give me the big money here.
dash pad 79scottsdale Interior 3 06-05-2012 09:11 PM
New Dash pad '69 Z-28 st3gamefarm Interior 3 08-20-2009 10:20 AM
recovering dash pad esahlin Interior 2 05-13-2009 11:44 AM
69 Camaro Dash Pad Install Question... camaro freak Interior 0 03-22-2008 09:19 PM
Dash Pad 69GTO Interior 1 08-25-2005 07:47 AM
