68 Camaro metal headliner trim - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 07:05 PM
Anyone know where to get the front and rear metal headliner trim pieces (with teeth)? Or advice on fabricating them?
Old 01-03-2013, 04:16 AM
camarocentral.com ? maybe...... call them they have always been very helpful anytime I have needed them..... or wouldnt landau top glue that upholstery shops use, hold it up there with the metal trim that goes across it ?
I'm betting our resident pro Dan will know
Old 01-03-2013, 07:59 AM
Thanks but
I already tried Camaro central, but they were out with no follow on help. What about fabricating them? Any suggestions?
Old 01-03-2013, 12:19 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Are you talking about the whole set of trim strips, front, rear and side? Rick's Camaro has them as a complete set or you can order front, rear or side sparately: http://www.rickscamaros.com/catalogs...liner&x=42&y=6
Old 01-03-2013, 01:46 PM
Dan
Dan that is the trim kit, what I am looking for is what the headliner tucks into. its metal with teeth, then the trim. Thanks for looking though!
Old 01-03-2013, 03:24 PM
Dan
Yes the headliner retaining stripes that are just inside the front and rear windshield.
Old 01-03-2013, 06:05 PM
Wiki Edits: 22
Do these things screw on and then the headliner is tucked under them? What happened to the originals?
Old 01-03-2013, 06:21 PM
Dan
Yes i believe itnis screwed in,but the headliner is tucked into it with glue. When I bought the car the front was missing, and the rear left side is rusted out.
Old 01-03-2013, 07:11 PM
prostreet6t9's Avatar
Differential/Driveline
Try classic industries.
Old 01-04-2013, 02:56 PM
That is the windless molding I do not need that but thanks.
Old 01-05-2013, 07:07 AM
Wiki Edits: 22
Can you post some pictures?
Old 01-06-2013, 05:09 PM
Found them
I found them in Houston a company called Camaro country.
bolts for headliner trim? Jason7504 Interior 5 03-08-2010 12:31 PM
80's GM interior mounting clips for headliner metal?? Help bubbahotep Interior 5 10-11-2008 09:41 PM
camaro headliner shortbed454 Interior 1 12-16-2005 08:15 PM
S-10 Headliner trim pieces?? TurboS10 Interior 4 02-08-2004 05:54 PM
Headliner Trim Question LostKnight Interior 2 11-12-2003 09:23 PM
