Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 68 Camaro rear seat rebuild questions
  #23 (permalink)
Old 06-11-2013, 08:15 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
You're doing just fine from what I can see. 1/2" sew foam will have more wrinkles than 1/4". Remember, this isn't steel or wood where you can be as precise as the equipment you cut it with, this is more art. The wrinkles will come out. My only criticism is aesthetic. Your pleats are very, very narrow in your insert. Narrow pleats are very hard to make good looking to the eye, especially vertical ones on 1/2" sew foam. In the future, 1 1/4" pleats should be the narrowest you use. The inserts are still well done. Hmmm, maybe it's just the picture is so small.
