68 Camaro rear seat rebuild questions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-09-2013, 01:25 PM
DanTwoLakes's Avatar
Wiki Edits: 22
How thick is the sew foam? If it's only 1/4" thick, you only need to sew around the border once. That is some very pliable vinyl, is it not? Remember, this is going to be stretched onto the seat frame, so almost all of those wrinkles will just come out when you stretch it, especially the rear seat back. Also, just put glue on either the vinyl or the sew foam, not on both.
  #17 (permalink)
Old 06-09-2013, 01:51 PM
JJ269J's Avatar
Thanks Dan. It is 1/2" sew foam. The vinyl is Whisper vinyl, and yes it is very pliable. If that looks normal, I will press on in hopes they pull out when I put the cover on. Dan, you make it looks so easy! For the most part nothing has been "hard", just new. I'm trying to take my time and minimize redo's! Thanks again.
  #18 (permalink)
Old 06-10-2013, 05:47 AM
JJ269J's Avatar
What's the best way to remove clay based marking chalk from tweed? I did not realize there where different type of chalks. I used this chalk to layout the vertical lines on the inset for the seats and went to brush it off and it is proving difficult. Any tricks of the trade for this, I hope?
  #19 (permalink)
Old 06-10-2013, 08:10 AM
Wiki Edits: 22
Air nozzle. It's best to just blow it off. It should come off easily. Next time try this chalk: http://sewtrue.com/Store/Jems-500-Ta...halk-P336.html
  #20 (permalink)
Old 06-10-2013, 09:01 AM
JJ269J's Avatar
Tried the air nozzle, some came off, a lot did not. I was expecting it to come easy and it did from the vinyl but not the fabric. I rubbed it lightly with my finger and a piece of scrap cloth. Still see it. Maybe I pressed to hard or something. It looks to be down in the tweed threads. Any other alternatives to remove it? I can get a pic this evening if it will help.
  #21 (permalink)
Old 06-10-2013, 09:42 AM
Wiki Edits: 22
Use Fantastik and a soft bristle brush.
  #22 (permalink)
Old 06-11-2013, 06:02 AM
JJ269J's Avatar
I made a little bit more progress last night on the cover. Most of the back section is complete. I just have two more pieces on the outside of each side and a small piece at the bottom middle to complete. Then I plan on test fitting it to see where exactly the listing tape needs to go to make everything tight. The original listing was just about non existent, so I could not get a good measurement.
For my first cover, I'm fairly happy so far. There is a little bit of wrinkling around the curves for the inserts (I guess I pulled on the material a bit trying to make the turns). I'm trying not to obsess over it. I had little bit of trouble getting all four radii to be the same. I tried to start and stop the turns at the same points, but I wasn't measuring how much angle I was moving the material after each stitch and I was trying to follow the selvage edge but they did not come out perfect. Looking back, it may have been better to draw the stitch line on the material and follow that since I'm new to this (the rest of the sewing, I've just been using the selvage edge as my guide. Anyway, here is a pic of where its at now. Comments/suggestions are appreciated.
  #23 (permalink)
Old 06-11-2013, 08:15 AM
Wiki Edits: 22
You're doing just fine from what I can see. 1/2" sew foam will have more wrinkles than 1/4". Remember, this isn't steel or wood where you can be as precise as the equipment you cut it with, this is more art. The wrinkles will come out. My only criticism is aesthetic. Your pleats are very, very narrow in your insert. Narrow pleats are very hard to make good looking to the eye, especially vertical ones on 1/2" sew foam. In the future, 1 1/4" pleats should be the narrowest you use. The inserts are still well done. Hmmm, maybe it's just the picture is so small.
  #24 (permalink)
Old 06-11-2013, 08:22 PM
JJ269J's Avatar
Yeah, the pleats are narrow. I like how it came out though. When I laid them out I measured 1 3/8" and after sewing they are about 1 3/16". Next time, I will definitely go a little wider. Here are a few more better quality pics:
The french seam (so-so):
  #25 (permalink)
Old 06-16-2013, 04:16 PM
JJ269J's Avatar
Hey guys. I finally completed the back section for the rear seat. For my first cover from scratch, I am happy enough with it. They are a far cry from the beat down things I replaced.
There are still a few small wrinkles, any tips for getting those out? What's the deal with steam or heat. I've read that helps but have never use it. Anyway, here are a few pics.
  #26 (permalink)
Old 06-16-2013, 10:50 PM
Wiki Edits: 22
You live in Florida, and the first time that seat gets warmed up in the sun it will be fine.
  #27 (permalink)
Old 06-17-2013, 07:55 AM
JJ269J's Avatar
Then it's the perfect time of year down here to sit them out in the sun for a while and see what happens. Thanks for all your input, Dan. Once I start on the bottom section and the front seats, I'm sure more questions will be coming your way.
  #28 (permalink)
Old 07-14-2013, 10:50 AM
JJ269J's Avatar
Hey guys,
I finished up the bottom section of the rear seat. Overall, I'm pretty pleased for my first attempt at auto upholstery. I think I need to readjust the back cover because the bottom cover is pulled very tight because of the listing at the center seams so the top and bottom covers are not in perfect alignment, but I can shift the top piece left or right and they line up. In other words, I think I need to pull the top cover towards the outside on both sides and everything should line up. There is no listing in the top cover center seams so its not stretched like the bottom is. Here are a few pics.
Top section shifted to the left:
Top section shifted to the right:
I also started tearing down the front seats. The driver's seat was in pretty sad shape and of course there are a few broken springs I need to repair. The question I have now is about the bottom cover and how it is secured to the frame. I have seen J hooks before, but these have what looks like a flat piece of plastic that slides under a lip in the frame. Does anyone know the name for this stuff or where to get it? The original is in fairly good shape, but I still do not want to reuse it if I can find a replacement. Here is a couple pics:
Bottom cover secured to frame:
Plastic channel (you can see the lip it slides under):
Oh, and here is what I'm starting with:
Thanks!
  #29 (permalink)
Old 07-14-2013, 12:55 PM
Wiki Edits: 22
It's also used on Corvette seats, and it is hard to come by. I have a supplier that handles it, but internet searches don't seem to work out very well. I'm pretty sure it is clear rigid vinyl, and would only come in sheets which you'd have to cut into strips. It's available in sheets of different thicknesses from U.S. Plastic online.
  #30 (permalink)
Old 07-22-2013, 08:55 PM
JJ269J's Avatar
Hey guys!
Here is a quick update, The UPS guy dropped off a present for me today. The front seat foam I ordered from TMI arrived. I got the sport R/II foam and the look pretty sweet. They look huge compared to the worn out stock foam.
While I was waiting for the foam, I tore down the original seats, repaired a few broken springs (the typical side springs were broken on both sides of the drivers seat), blasted the frames and sprayed them with rust encapsulator. Then I replaced all of the stake wire and upgraded the original burlap with a synthetic deck pad to protect the foam from the springs poking through. Now the real fun begins....I have to make the covers from scratch, cause the stock covers are nowhere close to use as a pattern.....this outta be fun for a newbie like me . Here are a few pics:
68 Firebird Camaro rear seat JBKuter Interior 2 05-25-2009 09:47 PM
1984 Camaro tranny and rear end questions Camaro2 Transmission - Rearend 14 03-30-2009 12:47 PM
68 firebird to camaro rear seat 68birdman Interior 24 11-24-2007 12:07 AM
Complete rebuild of GM 12 bolt rear, quick questions 406chevelle Transmission - Rearend 8 03-24-2007 03:02 PM
69 Camaro fold down rear seat busterbuddie Interior 1 01-16-2005 03:40 PM
