68 Camaro Steering Arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2007, 11:39 AM
Is a quick ratio steering arm and a standard steering arm the same length?
Old 03-21-2007, 04:00 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
The only differents is in the steering gear box. Someone correct me if I am wrong.
Old 03-21-2007, 04:25 PM
The longer the arm ... the faster it is ...
The shorter the arm ... the slower it is ...
That's on the same box
Old 03-22-2007, 08:55 PM
There were 2 or 3 different lengths of steering arms that fit that suspension design. The longer the steering arm, the slower the steering. Shorter arms are usually found on cars with power steering, but they'll work fine with manual steering, it'll just steer harder.
Pitman arms are the other way around. A longer pitman arm makes for quicker steering.
68 firebird into a 68 camaro? pi71 Hotrodders' Lounge 14 11-30-2009 07:24 AM
572 in 68 Camaro smac68 Engine 9 05-07-2006 08:07 AM
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 08:37 PM
Front Tires on a 68 Camaro 68coupe Suspension - Brakes - Steering 4 06-01-2003 10:25 PM
Need a steering colum for my 89 camaro KentuckyCamaro Interior 2 11-10-2002 03:11 AM
