68 Camaro - What Size Rims? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2005, 06:50 AM
FASTCAMARO
I have a 68 camaro with 15x8 rally rims on the rear. 275/50r15 MT et street radials. I am not sure if it has the right look! What size rim backspacing should I have?
Old 06-19-2005, 10:22 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
back space
Back spacing can sometimes be changed depending on tire heighth. The taller the tire the more sidewall bulge. Since the rims and tires you now have fit on the car. Measure the closest spot where the tire meets the inner fender or frame. You should have at least 3/4 of an inch clearance. If you have an inch and a half clearance you can buy a rim with a half inch less back space than the rim you have. To measure back space. Lay a straight edge across the back side of the rim and measure from the center of the rim to the straight edge. With slicks, they grow on acceleration. You want at least 2 inches of clearance around the circumference.
'68 Camaro front brake/disc power conversion problems nathanlburns Suspension - Brakes - Steering 9 05-14-2004 08:22 AM
Will rear parking brake calipers from 82-85 firebird fit my 68 Camaro? shockers69 Suspension - Brakes - Steering 1 04-19-2004 08:27 PM
rack and pinion on 68 camaro Streetrodfan Suspension - Brakes - Steering 4 04-19-2004 07:45 PM
68 Falcon Rims Jim69Mustang Body - Exterior 3 02-06-2004 10:31 AM
Shifter rebuild on a 68 Camaro duanecourt Transmission - Rearend 3 06-12-2003 06:19 AM
