Hey guys,Ive already done a search and didnt find what im looking for so mabey you can help.I am working on a 1968 dodge charger with a vinyl top.I need to remove all of the trim around the windows and remove the top.Im not sure what tool to use,and none of the tool truck guys know either......can you help!?Any advise or comments would be helpfull.Thanks in advance.
More details would help, but I do know that the trim around the bottom screws in from inside on a 69. As far as the drip rail trim, it pulls off from the bottom but requires patience to the 10th power so as not to tweek it beyond replacement. All of the weather seal trim screws on under the rubber. Better figgure for new rubber. It's been a long time since I did this but that's what I remember.
Hey Highlander.....thanks for the re.I am mostly refuring to the trim around the windows,and the trim around the vinyl top.If more details are needed I can submit pics.
DANG Bee4Me..........Thanks alot.That was alot of help,Problem solved!
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
