'68 chevelle; 350 turns over but won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2003, 05:25 AM
Red face '68 chevelle; 350 turns over but won't start
Need some help! For a while, my car would not start in the cold, even when I held the choke open. There was a slight miss at idle that I couldn't figure out,so I replaced the whole distributor and spark plug wires. Now it will turn over all day long but won't start at all. The only thing I can think of would be the timing...that's my next move. What is the gap setting on the spark plugs for my car? The plugs are pretty new and I think I have 'em gapped correctly. Help! I am so frustrated!
Old 02-03-2003, 07:30 AM
lookatme's Avatar
Post
you got the firing order right? of course you say. but are you sending spark to the right plug.you might have the distributor one plug off in your firing order. check to make sure that while the rotor is pointed at say #2 that #2 is in fact at top dead center. i think you just have all the plugs one off.
Old 02-03-2003, 09:56 AM
Post
could you be a tooth or 2 off when you dropped your distributor in?
Old 02-03-2003, 04:56 PM
Seon's Avatar
Post
What type of distributor..points? If so, check the condensor. Also check your resistor that it's reading 9 volts not the full 12 volts on the distributor side. I've had both condensor and resistor go out on me and drove me crazy til I discovered the problem. Good luck.
