68 chevelle recommended gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2011, 11:25 PM
I am running a 327 68 chevelle with a stock gm 10 bolt non posi rear end and the my bottom end is sluggish. I am running 245 60 r 15 in the front and 275 70 r15 in the rear pretty big tires. With a th350 with a 1800-2000 stall, what do you guys recommend for a good gear ratio and can you use the same 10 bolt carrier with a new or used posi ring gear and spider gears? I am not racing but would like some better bottom end and not kill my cruising rpm either something in between pls.
Old 05-06-2011, 02:21 AM
liquid launcher's Avatar
its a matter of physics .
is the engine stock or what horse power, transmission has to also hold up to engine out put next drive shaft & rear end need to be really thought of if engine is stock & transmission is stock there are horse power factors or you may walk.
all honesty the engine supplies the torque & rpm the transmission is a middle man the drive shaft & rear end is the so called hook up its where you will eather burn tires or go somewhere quickly usually a gear ratio of 3.9 called three ninties or 4.11 called four elevens are usually used unless you have more money than nuts or brains these gear ratios are a common option in gm 10 bolt or gm 12 bold you can make a stout 10 bolt or 12 bolt there are some veriables to look at just what do you want this car to do. stock gears 323 or so are called highway gears ask yourself if you want to do a lot of highway driving or is there a power freak in ya not sure if ya want to get so technical if its stock all the way through you may want to leave it and find another car to race once altered its up to supply & demand.
now if its a 425 horse radical small block it has needs to be accomodated for ya know no one talks about planting power yea Im a drunk farmer just think plant each gear & be quick there is also laws of physics not to bore you Im a person that knows what I need or want reality plays a part in this kinda self educated ok low down 10 bolt gm good up to 500 horse but needs replacement parts same with gm 12 bolt there are some rear ends that are tough out of bigger cars & trucks that you may never tear up if set up correctly.
ask yourself just what you want your car to do there are money pits then there are jenuine original cars I have seen some men with both only for the reason they could not have both in one car this is not a dumb question me Im smarter than money but kinda need both one car to the office the other by night believe me one of them is not insured or actually safe me I got ****ed I paid for concert drove there to find it was a closed show yea I got shut down call me if you would like 5-1-7-9-3-7-4-1-6-6- life is not allways what you can get from David. oppinions optional yours bad don't bother.
Old 05-06-2011, 06:57 AM
I can be much more precise.
Most street guys these days will go with a 3.55:1. However if you want more oomph on launch, you can step up to a 3.73 or a 4.11. Being a 3spd automatic, your gas mileage will suffer accordingly.
Old 05-06-2011, 07:00 AM
sqzbox's Avatar
My pipes are my music
Sounds like you need 3:73's. 4:10's would put you at 2,800 rpm at 60 with the TH350 and 31" tall tires, but will really get you going.
X-2 on the milage! I'm getting 10 mpg with my truck but it weighs 4,800 lbs.
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
recommended stall convertor for chevelle !72chevelless Transmission - Rearend 0 05-25-2006 07:29 PM
What's the gear ratio? JamesRS Transmission - Rearend 2 10-30-2004 06:53 PM
Gear Ratio? Mike_82 Transmission - Rearend 2 06-19-2004 12:10 AM
'70 Chevelle 2:73 ratio to 3:55 Seon Transmission - Rearend 7 10-13-2003 11:42 PM
