68 chrysler upper ball joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 03:36 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
Ok ive scoured the internet and searched everything I could on here concerning my 68 chrysler's upper ball joints. From what Ive learned I need a square socket and depending on the condition I can thread the old ones out and the new ones back in provided the bore is in goog enough condition and the new ones tighten to 125 ft-lbs. What I want to make sure of is from what I can tell I need a 1 7/8 socket, but theres a lot of different sizes out there. Also any tips or tricks would be great.
Old 09-18-2011, 04:56 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
It is a special socket
The one I have---but cannot find---is a 3/4" drive socket and I had to use a reducer for a 1/2" drive breaker bar.
Chances are real good that that sucker is in there real tight------gonna need a lot of leverage to get it out.
Have not worked on a Chrysler product since the 80s.
I did the front end on a 67 Chrysler 300-----440/4-spd car----stolen in 89
When you do find a socket----soak the threads with some penetrating oil for a day or two---might come out easier.
I would not worry about the threads----they will probably be okay.
While you are at it-----search around some junkyards for a 73 Full size Mopar and get the disc brakes----spindles and all.
Direct bolt in---I did this to my 300 because replacing the the calipers and rotors, even back in the early 80s, was way too expensive and the parts were difficult to locate. Mine had those 4-piston calipers and 2-piece rotors.
Old 09-18-2011, 07:24 PM
Wiki Edits: 5
I actually bought a 72 new yorker 440 w/disc so I could change it all over. Is the socket you used a 1 7/8". Several sizes out there and they are f^%kin expensive so I want the right one the first time.
Old 09-19-2011, 10:18 AM
It's 1 29/32" Google PN 68880
Old 09-20-2011, 06:18 PM
Wiki Edits: 5
what brand? just the number brings up the most random *****.
Old 09-20-2011, 07:26 PM
T-bucket23's Avatar
Wiki Edits: 26
A 3Ft pipe wrench works just fine. Took many out this way, soak it with PB blaster and it will come out. Sometimes you need to add a piece of pipe for leverage.
Recently did them on a Volare, came right out.
Never lost the threads on any and we did have some tight ones over the years.
Chet
Old 09-20-2011, 07:57 PM
http://assaultech.com/spc_performanc.../i-397715.aspx
Old 09-21-2011, 07:26 AM
T-bucket23's Avatar
Wiki Edits: 26
Those sockets are in most of the Ball Joint kits that you can borrow or rent from the parts stores.
Chet
Old 09-21-2011, 08:00 AM
Wiki Edits: 27
big hammer ?
To get tie rods and ball joints loose I hold my big sledge hammer tight against one side of the forged arm-spindle and hit the other side with another big hammer. The shock helps to get them loose easier than just pulling with a cheater bar.
Old 09-21-2011, 03:22 PM
T-bucket23's Avatar
Wiki Edits: 26
Those ball joints are actually screwed into the control arm. This is what he was asking about.
Chet
Old 09-22-2011, 07:03 AM
Wiki Edits: 27
tight fit ?
Holding the big hammer on a tight nut and smacking
the other side works , the shock wave usually help to break it loose . since the screw in part is still inside you won/t distort it.
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 02:39 AM
were can i get ball joints rtyauch301 Suspension - Brakes - Steering 6 09-02-2009 02:30 PM
Ball Joints....not a hot rod but.... screamin340 Suspension - Brakes - Steering 7 08-05-2005 04:51 PM
ball joints knuckles Suspension - Brakes - Steering 4 01-09-2005 10:41 PM
ball joints knuckles Introduce Yourself 2 12-28-2004 09:06 PM
