'68 dodge 273 v-8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2011, 10:26 PM
'68 dodge 273 v-8
will the 4 barrel manifold from a 318 fit on the 273?? i'm pretty sure it will but, would like to know for sure.hate to buy one ,then find out it wouldn't fit. james
Old 06-01-2011, 10:44 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, they're both "A" motors, so what fits one will fit the other. Only difference may be the size of the runners. If you have a mis-match there, you could do some gasket matching. Just be sure to run your cutter far enough down in the runner that the vessel doesn't look like an Anaconda that swallowed a pig in the side view. If you have a large volume like that at the intersection of the manifold/head, the intake charge will slow down there and drop fuel out of suspension. Then it'll be lean/rich/lean/rich/lean/rich as the fuel drops out and then gets picked up again and it'll be a tuning nightmare. Probably the best plan is to bolt it on and forget it.
Old 06-01-2011, 10:55 PM
273 v-8
thanks for the info.it's been a long time since i worked on these old dodge engines. james
Old 06-01-2011, 11:38 PM
General Martok's Avatar
Try and find 340 exhaust manifolds if they are around.
650 4bbl for 318 runs great edelbrock ele choke.
Dodge Warlock Parts? ( 1980 Dodge D150 ) Silentlion_69 General Rodding Tech 6 03-24-2010 08:17 PM
One Hot Dodge powerleg5 Engine 2 11-09-2004 08:01 AM
is my dodge 3.9L V6 worth keeping or should i go for a dodge 360??? mopar_101 Engine 2 07-25-2004 11:04 AM
DODGE 340 SLANT SIX Engine 9 01-26-2003 03:35 PM
