68 firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2007, 07:06 PM
Last journal entry: building a turnover
68 firebird
i have a 68 firebird. i would like to know how hard is it to reilign the front frame with body if i take it apart.
Old 04-12-2007, 08:06 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Its about as hard as convincing a blonde that the moon really IS made of cheese Its not hard at all, theres alignment holes on the frame and body and also some measurements on my site http://home.sport.rr.com/cdjrracing/f-bodyframe.htm
Old 04-12-2007, 09:31 PM
Exactly, use the alignment holes on the center mounts and also do some cross measuring all the way back to the leaf spring perches just in case the factory didn't jig the car properly during assembly. I've seen many times where people didn't align the subframe and then fought with the sheetmetal alignment and also front bumper, if the subframe is square with the body then the sheetmetal will align easily and also the front wheel alignment.
Old 04-13-2007, 04:47 PM
68 firebird
thanks for the the help. well going to take it apart tonight.thank again
Old 08-04-2007, 05:49 PM
FIREBIRDTONY's Avatar
Last journal entry: the rear body panel
hope this helps
68 firebird into a 68 camaro? pi71 Hotrodders' Lounge 14 11-30-2009 08:24 AM
68 firebird rear disc brakes TORI1 Suspension - Brakes - Steering 3 01-15-2009 10:37 AM
68 Firebird quarter panels jerschopshop Body - Exterior 2 01-16-2005 10:55 AM
'68 firebird spring perch distance firebirdmi Transmission - Rearend 0 02-07-2004 05:05 PM
Custom 68 Firebird 054teamdaddy Interior 1 01-26-2002 11:03 PM
