68 firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2007, 07:05 PM
billme83's Avatar
68 firebird
I am in arizona and i just picked up a 68 firebird. Definately a project (non running) Has little rust and missing a bunch of parts. I was told that it had a 455 (non original) motor in it and knowing little about pontiacs i belived him. With about an hours wouth of research i found out that it has the original pontiac 350. Still unsure what tranny it has but if it is origial it had a powerglide (also know very little about these trannys other then they are two speed trannys) i have a couple of questions...I have heard that pontiac 350s are kind of junk motors and to replace it with a chevy. What is the difference between a 350 and a 455 if they are both bigblocks (is it just bore and stroke??) And are powerglides good trannys to use or should i convert to a manual 4 speed??? Any advice would help. Thanks!!
Old 11-09-2007, 08:58 PM
One thing you should keep in mind, if you have the original drive train in the car it'll be worth a lot more if you keep it that way.
Old 11-09-2007, 09:23 PM
79C10's Avatar
Viva la Migra!!
I concur the $ value comment. I have never heard of a big block 350 though.
Old 11-09-2007, 10:11 PM
WDCreech's Avatar
Grumpy Old Goat Herder
There are no "Big Block" or "Small Block" Pontiacs. Externally, the 326, as well as all those in between, is the same size as the 455. The two speed tranny that you have is not a Powerglide. It's a Super Turbine 300, which is not as good as a Powerglide, but like the Powerglide, is dementionally interchangable with the Turbo 350. So, you could pull that engine and transmission out and drop a 400 or 455 with a TH350 right in.
ID:	25422   Click image for larger version
ID:	25423   Click image for larger version
Old 11-09-2007, 10:17 PM
Ok where should I start? First off there are no big or small block Pontiac's. The differences are not just in the bore and stroke but the main journal size of the crankshaft. The 326,350. 389, and 400 all have 3 inch main journals. The 421,428, and 455 all have 3 3/4 inch main journals. All the block demensions are basically the same. Second the Pontiac did not use a Powergllide transmission, what it was called escapes me right now. Third the 350 is not a boat anchor engine as there are kits out there to really make them perform. Ken (Ace) Brewer of Pacific Performance Racing in California has developed a 383 stroker kit for a 350 Pontiac that develops 462 horsepower on pump gas. Also check to see what the block code is, two letters right under the passenger side head and check to see what the head castings are. The head codes will be on the center ports. Also Pontiac had a 350 HO in 69 that, in the right tune could run with about anything out at the time, 320 hp from the factory. Why put in a small block Chebbie when the torque of a Pontiac will put it to shame. Beside when have you ever heard of anyone running a small block Chebbie destroying frames, as I have destroyed 2 under my GTO running a mild 400 Pontiac. Why? Answer, Torque. I know alot of the Chebbies guys on here won't agree with me on alot of this but facts are facts. It may cost more to build a Pontiac but the results are more satisfying. If you have any questions feel free to contact me by PM.
Old 11-10-2007, 08:42 PM
WDCreech's Avatar
Grusome Goat, I think that you and I have about the same feeling for puttin' a chebby in a Pontiac. We would probably get along real well. Also, it was more than likely a typo, but the 421, 428 and the 455 have 3.25" mains, not 3.75. And Pontiacs did get powerglides in the mid 70s, when the plant that made turbos was down for a time, but a '69 would have a Super Turbine 300, which was okay, but not as good as a Turbo 350 or 400 or a powerglide.
Old 11-10-2007, 10:06 PM
bullheimer's Avatar
NEVER use credit cards!
ditto and ditto. pacific has a website, just put w cubed in front of their name. ps. all poncho rods are the same length too, but pistons aint. get the stroker crank, have somebody well known port the heads like sdperformance.com and i would lose the ST300 and put in a th350 (bolts right in with a kick down kit from.....??? crap shiftworks or something??) or a th400 if you can get one and the driveline to go with. actually, you may be able to getta 4 speed. that would be much better for me but spendier if you have to buy pedals etc. bout time we got some pontiac brains around here.
also, tho not as good as this site performanceyears.com has an all pontiac bulletin board with ten tons o'crap on fixing anything firebird or pontiac.. or you can try www.nastyz28.com if you had a second gen bird but it is only for second gen camaros. other sites abound, i have made poncho posts here without much help. but that was a year or so ago. i would take up gruesome on his pm invite and see how that works out
God, that is one BAD *** 64 creech!!!!
Old 11-11-2007, 07:03 AM
Wd yes it was a typo as I was about half asleep and working in the dark. I am as hardcore Pontiac as you. Catch alot of flack for putting a 400 in my 85 GP instead of a Chebbie. And always have some idiot ask me why I won't put a Chebbie in my GTO. I always tell them I get tired of changing engines and besides it has Pontiac on it, not a Tie. Bull, Py has a very good all Pontiac site as I have been a member of that board for about 5 years now. Going to join a couple of more as there is no way I'm going to go to anything else as far as brands, getting to old and besides I don't think I'd find anything that I'd enjoy more that the 71 GTO I've had for the last 21 years, and I have owned and drove abput everything over the years.
Old 11-11-2007, 07:57 AM
Will I ever get it done?
Last journal entry: Hood
Not sure if I agree with that with regards to a Poncho 350 and a ST300. If I had my choice between o/w identical 68's, I would be way more interested in a 455 (or 400) / TH400 (or TH350) than a numbers matching 350/300.
Anyway, like WDCreech said, you can pull the 350/300, set it aside, drop in a 455/350 while hanging on to the original powertrain in case you want to put it back to stock. You could also use a TH400 and hang on to the original crossmember and driveshaft to put it back to stock someday.
68 firebird into a 68 camaro? pi71 Hotrodders' Lounge 14 11-30-2009 07:24 AM
68 firebird to camaro rear seat 68birdman Interior 24 11-23-2007 11:07 PM
68 firebird shattersoul383 Introduce Yourself 1 05-11-2007 05:40 PM
68 Firebird quarter panels jerschopshop Body - Exterior 2 01-16-2005 09:55 AM
'68 firebird spring perch distance firebirdmi Transmission - Rearend 0 02-07-2004 04:05 PM
