68 firebird - 73 camaro disc brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 09:24 PM
bluebird
I have a 68 Firebird that has drum brakes on the front . I have a wrecked 73 Camaro that has disc brakes on the front . Is there a way I can make these brakes fit the 68 Firebird. I`m told I can swap left and right spindles and it will work. Any help with this would be appreciated.
Old 08-23-2012, 11:31 AM
purple fifty one's Avatar
brake swap
thats affirmative
Old 08-24-2012, 09:42 AM
Originally Posted by purple fifty one View Post
thats affirmative
NOOOOOOO!!!!!
This question comes up about every other month.
I'll say this again. YOU CANNOT USE THE LATER SPINDLES!!!
There are two problems. First, there's the front vs rear steer issue. Swapping the spindles side for side puts the steering arms in the wrong place and will cause bump steer that will make the car change lanes when you hit a bump. Second, the 70-up ball joints use a different taper angle on the studs. Yes, you can bolt the later spindles up to early ball joints, and this will work fine until one day the metal fatigue due to the improper fit causes a front wheel and spindle to depart the car.
Did I mention not to do this?
The 67-69 F-body, 64-72 A-body, and 68-74 X-body cars all use the same spindles. Repro disk brake spindles are available EVERYWHERE. If you're too cheap to buy the correct parts, then you can also convert your drum spindles to disk spindles with some simple machining, as detailed here:
Brakes
Old 09-06-2012, 11:09 PM
67-69 disc brake spindles
You can use the spindle, caliper, bracket, or rotor from the below models IF the car came with front disc brakes. Drum spindles can be modified to disc use by cutting the upper boss. You will still have to 67-69 steering arms.
Apollo 73-74
Buick Special 69-72
Camaro 69
Chevelle 69-72
Firebird 69
Grand Prix 69
Grand Prix 70-72
Monte Carlo 70-72
Nova 69-74
Olds F85 69-72
Omega 73-74
Sprint gmc 71-72
Tempest 69-72
Ventura II 71-74
The Following User Says Thank You to cdminter59 For This Useful Post:
purple fifty one (09-07-2012)
Old 09-07-2012, 10:53 AM
My bad!
Got bit by front steer/rear steer again! Thanks for good info....
82-92 Camaro/Firebird Disc Brake Posi Rear End JohnnieBoy Suspension - Brakes - Steering 3 04-16-2011 03:09 PM
79 Firebird rear disc emergency brake adjust retiredusncustoms Suspension - Brakes - Steering 6 01-18-2011 01:06 PM
Help with 68 camaro emergency brake install disc brake jdp2603 Suspension - Brakes - Steering 4 02-13-2010 08:56 AM
68 Firebird Disc Brake Swap blacktoothgrin Suspension - Brakes - Steering 12 02-16-2007 08:40 AM
1968 Firebird Rear Disc Brake Conversion TORI1 Suspension - Brakes - Steering 3 07-21-2006 03:17 PM
