Hotrodders Bulletin Board
#1
68 firebird to camaro rear seat
I am in the process of restoring(?) a 68 Firebird. I am nearing completion and am running out of $. I also like the look of the Camaro standard upholstery better than the standard Firebird seats. I purchased a set (front and rear) Standard Black PUI 68 Camaro seat covers. After installing the new covers on the front buckets (which turned out beautifully), I started laying out the rear seat covers. I noticed that the new Camaro upholstery was right at 2" too wide on each side for the Firebird seat that I was attempting to cover.
#2
I assume this is a bench seat top and bottom. Are you talking about 2" too big side to side? You need to take the seat and seat cover to an upholstery shop. Making them smaller is relatively easy, and if you can re-upholster the seats yourself, it shouldn't be too expensive. If you've got 20K invested in this thing, a couple hundred more to fix the seats will be well worth it. It sure beats eating the seat covers you have and starting over. As far as the rear panels go, get the right ones for the car. There are all kinds of websites that sell exactly what you're looking for. If you can post some pictures, I can tell you exactly how to make the seats smaller.
#3
Birdman -
The trouble you have run into is that all the 1st gen Firebirds had rear armrests whether coupe or convertible, standard or deluxe. 1st gen Camaros had a wider backseat in standard interior coupes (and 69 deluxe coupes, if you want to venture into the "more than I needed to know" category. Anyway, if you can return or sell the cover set you have, you want a standard backseat cover for a convertible and/or fold-down rear seat Camaro. That's the only way to get standard 1st gen Camaro upholstery for a narrow backseat. Your F-bird armrests will be fine. |
#4
Good info, Eric
#5
We Camaro guys run into this question a lot... Lots of guys with verts that lost their seats along the way.
And we all know that "Firebird" is just French for "donor car". Please don't flame me, I just could not resist. |
#6
Super info Eric. That's why this forum is the biggest on the web........super knowledgeable guys(and gals) like you! BTW nothing wrong with playful teasing of the Pontiac guys!
#7
Ill just pretend I didnt even see that Firebird comment, E
#8
What Firebird comment?
#9
The "donor car" comment lol. (I must admit, it did make me laugh pretty hard though)
#10
I thought "donor car" was a given? Just kidding! CDjr: What are you doing up so late?
#11
LOL Oh yall aint right for that!
You DO realize the Camaro was just the "baby brother", right? |
#12
I always kinda figured that all 'Birds got rear arm rests so that the blue hairs that favored them could get out of the back seat when they got to their hot Mah Jong tournament.
Camaros needed the bigger back seat for all the, umm, activity that their clean good looks generated... |
#13
Camaros had bigger back seats because of the bigger butt size of the um, guest occupants the average Camaro owner picked up.
Time for some Firebird Camaro Smack Down? ![]() |
#14
Actually the seat is 2" too narrow on each side for a total of 4 inches and I need to make it bigger. I have attempted to find a new reproduction seat frame and foam but there are no manufacturers making rear seats. I am attempting this weekend to take another seat that I acquired and using some ingenuity and some of the clips (i don't know what they are called but they are tubular shaped and split down one side and you crimp them together around parts of the seat frame) and my mig welder to increase the dimensions of the frame. I will then attempt to use the good old electric knife and form new bolsters with high density seat foam. I am lucky enough to have a place here in KC (Muscle Cars Inc.) that can get me just about anything that is produced. I'll let you know how it goes. |
#15
Thanks Eric Actually that is the exact information that I was looking for. |
Back to top |
Similar Threads for: "68 firebird to camaro rear seat"
| Can I make my 78 firebird into a Camaro? | Suckingas | Body - Exterior | 7 | 08-29-2006 03:32 PM |
| Switching 71 Camaro 10 Bolt Rear End To Disc Brakes | TORI1 | Suspension - Brakes - Steering | 1 | 04-13-2006 03:38 PM |
| 73 Camaro 12 bolt rear end???? | 406chevelle | Transmission - Rearend | 3 | 03-12-2006 10:07 PM |
| Will rear parking brake calipers from 82-85 firebird fit my 68 Camaro? | shockers69 | Suspension - Brakes - Steering | 1 | 04-19-2004 08:27 PM |
| 4th gen firebird rear in a 68? | 67bird | Transmission - Rearend | 2 | 03-12-2004 02:13 PM |
