68 Firebird Camaro rear seat - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 07:24 PM
bluebird
The 68 Firebird that I bought has Camaro rear seats and of course it is the wide seat. The upholstery that I bought for it is for the narrow seat. What I need if anyone could help ,is the correct seat frames for the Firebird . And the armrest if possible. Or if there is someone that can stitch me up some Firebird cloth to match the front seats that will fit the wide frame. thanks
Old 05-11-2009, 08:28 PM
The rear seat springs (upper and lower), rear armrest metal and rear armrest vinyl are all available from the aftermarket companies for the 68 Firebird. The new aftermarket rear seat springs are expensive so your best bet is to look for a used Firebird rear seat and then buy the new Firebird vinyl to cover it. A place like http://www.classicindustries.com/ has all the parts available so you could look through their catalog to decide what you would like to do.
Old 05-25-2009, 08:47 PM
bluebird
firebird rear seat
Problem solved, found all seat frames with the arm rest local. Guy at work had them and they were in perfect shape. Thanks for help
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
73 Camaro 12 bolt rear end???? 406chevelle Transmission - Rearend 3 03-12-2006 10:07 PM
Will rear parking brake calipers from 82-85 firebird fit my 68 Camaro? shockers69 Suspension - Brakes - Steering 1 04-19-2004 08:27 PM
Rear end for 67 Firebird 400 pringles Transmission - Rearend 5 10-09-2001 08:07 PM
