68 Firebird Motor Mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2013, 12:05 AM
I have a 68 Pontiac Firebird with a Pontiac 400, Edelbrock heads, and a hyd. roller cam. I ordered a set of motor mounts from Autozone and the bolt hole is not deep enough. I have to add 2 washers to get the bolt to secure to the frame. There is not a huge selection for these mounts. What do guys think my best options are?
Old 03-09-2013, 07:18 AM
LATECH's Avatar
How many threads does the bolt screw in?
You are taliking about where the mount pins to the car itself and not the mount to the block...correct?
Fact is stranger than Fiction
Old 03-09-2013, 07:25 AM
BOBCRMAN@aol.com's Avatar
I had the same problem POS mounts made in Bangladesh!!
Old 03-09-2013, 07:35 AM
LATECH's Avatar
That sucks. I threw away a set of mountd from a 1965 Bonnie , sad thing is they were in good shape, It appeared like they were the same as an early F body. Wish I had known.
I was gonna E bay them , but figured it wasnt worththe hassle.
Old 03-09-2013, 02:23 PM
Bolting it up to the block is no issue. It's where the bolt goes between the mount and frame.
Old 03-09-2013, 03:52 PM
if you beat my boat, well race
you went to autozone.
they prollbally gave you camaro mounts
Old 03-09-2013, 04:08 PM
Try Year One in Braselton Ga. or NPD, National Parts Depot in Ocala, Florida. Both should have the correct motor mount for a 68 Pontiac Firebird. Tell them it is not the same as a camaro as the Pontiac motor is a different configuration. I also have a 68 Firebird. It is hard to get correct parts from Autozone or the local parts distributors. Good luck.
Old 03-10-2013, 10:34 AM
Ames Performance and Performance Years are, IMO, the best places to buy Pontiac parts. They, unlike those listed previously, deal ONLY with Pontiacs. They don't HAVE Camaro parts...
We have a NAPA store right next door. We get mounts from them. Sometimes made in China, some in India, SOME in "USA"(!). If your local store has a real parts person, and not just keyboard cowboys, they can get you exactly what you need, and reasonable in price.
Yes, Lynn, B-body and F-body had the same mounts in that era.
Another solution to the problem is to use new bolts, without the "extension" that protrudes from the threads. The stock bolts look a lot like an oil pan drain plug. That added nub is bottoming in the hole. If you get a good grade 8 bolt with the same thread length (1/2-20 threads), it will be all the way "in". A "hard" washer is also required. Most hardware suppliers, the 7/16" washer is more effective on the 1/2" bolt.
Jim
SBC in 73 firebird engine mounts and headers help elcaminodragster Engine 2 11-21-2011 07:28 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 10:52 AM
motor mounts big-bad-bob Engine 9 12-03-2006 01:10 PM
Motor mounts 1948 thames Engine 3 09-14-2006 06:57 PM
motor mounts robbysapien Engine 9 10-30-2003 05:03 PM
