Might want to check if the power brake booster is connected to it???
Some vehicles had a canister for that purpose. Not sure---just a thought Bryan |
No its not for the brake booster, but thanks for reply. It has a vacuum hose that enters through the firewall and into the interior, if i'm not mistaken it runs towards my a/c controls.
That sounds like the same setup used in my pickup, except that on the pickup there is space to mount the canister near the firewall.
If you really don't need the canister for your vintage air setup, you can follow the line back to the intake manifold and either plug it or change to a different fitting. In most cases there is a large line connected to a fitting on the intake manifold, and then a junction that T's out to multiple lines. Mine connects to the vacuum line for the HVAC and a line to the TH350 modulator. Bruce |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| Vacuum advance hooked up directly to manifold....is this bad????? | Steve-0321 | Engine | 66 | 08-21-2009 06:37 PM |
| Vacuum adv.. | underdog305 | Engine | 58 | 01-30-2007 11:19 AM |
| No ported vaccum port in my Q-jet, help | Augusto | Engine | 11 | 12-27-2006 05:04 PM |
