68 Gto - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2011, 12:49 PM
68 Gto
trying to identify block casting #486641 code YS Help
Old 05-15-2011, 01:21 PM
LATECH's Avatar
not finding that number. Is that number "Cast" into the block somewhere or is it "Stamped " into the block next to the "YS"?
Old 05-15-2011, 01:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 i don't have that # either.
Cole
Old 05-15-2011, 07:06 PM
the numberis cast directly above the YS
Old 05-15-2011, 08:14 PM
LATECH's Avatar
Those are stamped and they are the sequence number. Look at the engine back by the distributor hole. there is a number back there
9790071 would be a 1968 400 block.
post what you find.
Old 05-15-2011, 11:28 PM
WDCreech's Avatar
Grumpy Old Goat Herder
There will be a four digit date code cast behind the distributor, It will start with a letter followed by three numbers. The block casting number is behind the pasanger side cylinder bank.
Bill
Old 05-16-2011, 11:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
YS is going to be a 2-bolt main 389 or 400. Once you have the block c/n and the date code you can pin it down exactly.
Code Car Year CID HP Trans RPO VIN Carb Block Cast Main Notes
YS A-body 72 400 250 Turbo 400 L-78 R 1x4 481988 2 GTO
YS A-body 71 400 300 Turbo 400 L-78 1x4 481988 2 GTO
YS A-body 65 389 335 Powerglide 1x4 9778789 2 GTO
YS A-body 66 389 335 Powerglide 1x4 9778789 2 GTO
YS A-body 68 400 350 Turbo 400 L-67 1x4 9790071 2 GTO
YS A-body 69 400 350 Turbo 400 L-67 1x4 9790071 2 GTO
YS A-body 70 400 350 Turbo 400 L-67 1x4 9799914 2 GTO
YS X-body 74 350 200 Turbo 350 L-76 K 1x4 488986 2 GTO low comp
YS A-body 67 400 335 Turbo 400 L-67 1x4 9786133 2 GTO Califorina
YS A-body 73 400 230 Turbo 400 L-78 T 1x4 481988 2
YS B-body 72 400 250 Turbo 400 L-78 T 1x4 481988 2
YS B-body 71 400 300 Turbo 400 L-78 1x4 481988 2
YS B-body 78 400 180 Turbo 350 L-78 Z 1x4 568557 2
YS F-body 72 400 250 Turbo 400 L-78 T 1x4 481988 2
YS F-body 73 400 230 Turbo 400 L-78 T 1x4 481988 2
YS F-body 71 400 300 Turbo 400 L-78 1x4 481988 2
YS F-body 75 400 185 Turbo 350 L-78 S 1x4 500557 2
YS F-body 76 400 185 Turbo 350 L-78 Z 1x4 500557 2
YS F-body 70 400 330 Turbo 400 L-67 1x4 9799914 2
Old 05-17-2011, 12:09 AM
WDCreech's Avatar
cobalt, Pontiac didn't use a Powerglide in '65 & '66. What they had was called a Super Turbine 300. A two speed, yes, but not a Powerglide.
Old 05-17-2011, 12:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yeah. Might want to let them know over at Pontiac Power. But I'm pretty sure anyone should realize that a 2-speed transmission is what is being inferred, incorrect as the terminology may be. Similar to when the Dual Path is called a Dynaflow.
