68 GTO build-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2002, 03:55 PM
Vaughn68's Avatar
New Member
Red face 68 GTO build-up
I need some advice from ya'll. Ihave a 68 GTO w/ a new 400, Edelbrock intake & carb. I have screwed with the carb so much I'm tired of looking at it. I have a massive stumble/ hesitation off the line that I cant work out. I have been thinking of changing over to a Holley Street Avenger. Any suggestions? <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 09-13-2002, 03:57 PM
Post
How old is the carb?
aka Duke of URL
Question
Have you verified proper vacuum advance on the distributor and that the advance weights are not hanging up?
Old 09-13-2002, 06:05 PM
mr_chickenhead's Avatar
Post
I do not know anything about those edelbrook carbs but when ever I have "Carb troubles" I run to Sally (rochester under bed) Most car guys have that one carb that works all the time on on every application. If you do not have one, I am positive that one of your budies does. Borrow his for a day!!!
Old 09-13-2002, 11:25 PM
Croz's Avatar
Hotrodders.com moderator
Post
My suggestion is to go to a Holley. I have a 69 GTO with a 400 engine and a Carter carb and it does the same thing. Just to make sure, try what Mr. Chickenhead said first.
