68 GTO :narrowed rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2013, 09:52 PM
Hi, I want a narrowed rear end under my 1968 LeMans so I can have a deeper dished wheel. What is the best swap to achieve this? I was told late model S-10 or late model Camaro 10-bolt rear ends are narrower. I am wanting to run the stock four link suspension and also want disc.
Thank you, Greg
Old 04-21-2013, 04:38 AM
poncho62's Avatar
Wiki Edits: 5
You are not going to find another rear end with the mounting points that you need, other than another "A" body GM.....The pre 68 rears are about 1" narrower, but thats about it. Best to get your existing rear narrowed or maybe a custom built 9" Ford or something strong if you are going to go that route.
There is much more you need to look at than just slapping in another rear....The frame is likely needing to be modified too to accommodate the larger tires
The Following User Says Thank You to poncho62 For This Useful Post:
Crosley (04-21-2013)
Old 04-21-2013, 08:05 AM
big gear head's Avatar
High Performance Rear Ends
You can't narrow an A body rear end very much without getting into the lower controll arm mounts. The stock suspensoin is going to limit the amount that you can narrow it. As stated above, there are no other rear ends that you can use with the stock suspension other than the A body rear ends.
The Following User Says Thank You to big gear head For This Useful Post:
Old 04-21-2013, 09:07 AM
vinniekq2's Avatar
You wouldne be the first person to narrow the frame rails.It can get expensive,,,
Narrowed rear end... 77bronco_ed General Rodding Tech 7 12-09-2010 06:38 AM
narrowed rear end 65ramblinwreck Transmission - Rearend 8 09-13-2006 09:27 AM
narrowed rear end 85 regal Transmission - Rearend 2 12-14-2003 09:31 AM
narrowed rear end and gear selection Blob Transmission - Rearend 7 11-26-2003 07:40 PM
narrowed rear end beetle9 Transmission - Rearend 5 04-02-2002 02:08 PM
