68 GTO Wiring Diagrams and Hide-a-way Headlights Vacuum Source - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 10:57 PM
Hello, My name is sam. I am finally finishing a 68 GTO restoration. I am seeeking information as to where to get a wiring diagram for this car and also can anyone help out with the vacuum source to operate the hide-a-way headlamps.
Old 08-03-2011, 08:00 AM
Cannot help with the wire schematics, 68 Goat would be pretty straight forward depending on options. What I am saying is GM is GM and you could use just about any wire digram of the year. The source for the vacuum will be off the manifold.
Old 08-03-2011, 05:58 PM
Pantaz's Avatar
Here you go...
1968 GTO Wiring [PDF]
(The last page includes a diagram of the headlight door vacuum circuit. Note the check-valves. Those are very important.)
1968-69 GTO Hideaway Headlights [PDF]
This is from the Headlights PDF:
Item 45 is the vacuum canister. If yours is missing, the headlight doors will probably not operate.
Wiring Diagrams notwired Electrical 2 08-11-2009 11:20 PM
Wiring Diagrams notwired Electrical 5 10-23-2007 03:11 PM
wiring diagrams akm Electrical 4 12-24-2003 01:43 AM
Vacuum Diagrams for Cadillacs Izzy Engine 1 09-04-2003 03:09 AM
69' Camaro RS Vacuum Hide-away Headlights PrimaDude Engine 1 11-18-2002 01:46 AM
