68 mustang 8" to 9" swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 06:12 PM
fla68rustang's Avatar
"Restoration in progress"
Last journal entry: The "Rustang" with an epoxy bath
I am looking to change out my 8" rear for a 8.8 or 9" with disc brakes and posi and preferred 3.55 gears or similar. Can anyone tell me if the late model mustangs or others will work somewhat easily? Also i have en extra 3to3 1/2" worth of room in the rear now. I believe that the measurements for my 8" rear from flange to flange is 54". The other option is to add a rear posi with gears and a disc brake setup for around $1200.00 thanks for any info!
Old 07-31-2005, 07:17 PM
aka Duke of URL
What engine and HP rating?
Old 07-31-2005, 07:28 PM
re:68 mustang 8" to 9" swap
Original 289 slightly modified with c4 from jackson racing. Nothing exceptional. Mostly show.
Old 07-31-2005, 07:29 PM
lluciano77's Avatar
I'd stick with the 8". They are strong rear ends. The front discs should be sufficient. If you want to do the change it is going to cost some $$$.
Old 07-31-2005, 07:30 PM
aka Duke of URL
An 8" will hold approx. 300 HP. Would it be cheaper for you to find a 9" or just build what you have? The discs are no problem. Adaptors and you can use MARK VII rear disc. I don't think you want the 8.8".
Old 08-01-2005, 07:49 AM
re: 68 mustang 8" to 9" swap
It has front disc, and I wanted it all around but it sounds like it would be easier and probably more cost effective in the long run to stick with the 8" and add rear disc and a posi 3rd member with gears right? Has anyone had good experiences with getting a whole posi 3rd with gears at a decent price? I've seen them on ebay for around 5-600 with shipping. Thanks for the info guys. I've only been on here 1 week and I love it.
Dustin R.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
68 Mustang 390 with Dual Quads tommytempest Engine 20 12-14-2004 02:56 PM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
Axle replacement for 68 Mustang rosw Transmission - Rearend 2 10-02-2002 03:30 PM
