68 Mustang Dies When Headlights Are Turned On - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 10:55 AM
JParker77's Avatar
Anyone ever have this problem? Cant drive at night, because as soon as I turn the headlights on the car will begin to stall. If I give it gas/keep the rpm's up it will stay running. Any Ideas??
Old 10-19-2012, 11:03 AM
vinniekq2's Avatar
check voltage at battery when lights are on.My Acadian did that when I was in school.too low of voltage and points
Old 10-19-2012, 11:18 AM
JParker77's Avatar
At idle lights off, voltage is roughly 13.15
Idling with lights on voltage 12.75
When I put it in gear the car dies when the lights are turned on
Transmission ground??
Thanks!
Old 10-19-2012, 11:24 AM
vinniekq2's Avatar
should be 14 ish.Do you have points? is there a resister on the coil wire?
Old 10-19-2012, 03:42 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Vacuum?
How does the car run otherwise?
Nice and smooth?
What is warm curb idle RPM / vacuum readings?
Idle RPM in gear / vacuum readings?
Sometimes the additional load of the alternator is the proverbial "straw that broke the camel's back" ...
Old 10-19-2012, 04:13 PM
JParker77's Avatar
It has it's moments where it runs really well. Lately, it will occasionally want to stall in gear sitting at a stop light. Turning the headlights on will kill it immediately. Unfortunately, I no longer have a lot of the tools need to check vacuum and compression etc, so I'm just trying it by process of elimination.
At idle in Park, it usually runs great.
I replaced a couple vacuum lines and clamps, as well as the spark plugs and that seemed to help a bit. I am trying to borrow a few tools now to check some other suggestions, but am limited on funds and definitely cant afford a trip to a mechanic.
I really appreciate your response and input
car dies when I turn on headlights onebadmerc Electrical 15 06-24-2009 06:44 PM
How the scoop turned out. staleg General Rodding Tech 8 12-23-2008 11:17 PM
1966 mustang coupe headlights wont work sherriff Electrical 1 09-26-2008 10:13 AM
Car dies on brake or headlights..? 79454 Electrical 4 05-09-2007 10:02 AM
Uh oh, someone turned 18 Classix_Lover Off-Topic 6 08-07-2006 04:07 AM
