Thread Tools Search this Thread share on Facebook
  #1
Old 10-22-2010, 07:31 AM
readdirections readdirections is offline
68 mustang disc brakes
my 68 mustang fastback gt 390 has front disc brakes. my son rebuilt the rear end and installed 94 mustang disc brakes and a rebuilt power booster and master cylinder. with a front and rear disc system, do i still need to install a proportioning valve for the rear? also on the master cylinder is the front chamber for the front brakes and the back chamber for the back brakes. i tore this car down 20 years ago removed all brake and gas lines and did not take pictures of the brake system, dumb me. thanks for any input.
Register now (free) or login to remove ads
Old 10-22-2010, 04:31 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
It should be like this the front or the smaller reservoir on the M/C is for the rear and the larger is for the front. As far as the proportion valve i would use one just make sure you get one for disc brakes not for drum. JMO
If my memory is correct there is a difference between the two valves.
Cole
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "68 mustang disc brakes"
ThreadThread StarterForumRepliesLast Post
Power boost drum brakes vs. disc brakes???woodscavengerHotrodding Basics1308-08-2007 02:07 PM
Hotrodders Knowledge Cluster: Disc Brake ConversionsJonSuspension - Brakes - Steering008-29-2003 03:34 PM
disc brakes for 1968 ford galaxiechevblazk5Suspension - Brakes - Steering208-13-2003 02:58 PM
disc brakesblack66Suspension - Brakes - Steering205-02-2003 06:15 PM
Rear end and disc brakes for a 66 mustang couptreunoTransmission - Rearend504-23-2002 10:54 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
